Gearing
allispuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Topic: Gearing
    Posted: 19 Aug 2018 at 7:16pm
I was wondering if anyone knew of a gear that a person could swap out to make a gear between 1 and 2nd in a wd45. Every where I pull is either low gear or 4mph and I’m on 38s with the gas rear end so I don’t want to loose the fast 1st for the low gear classes but want something that is less of a jump for the 4mph
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2018 at 4:10pm
So, you want a slow second gear ??  I think I can make you one that would be halfway between 1st and 2nd gears.  It will require tearing down the whole transmission/rear end to install it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2018 at 4:36pm
Yeah I’m wanting something between the two. What would it cost to have one made?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2018 at 7:41am
PM sent.
