F 250 Super Duty Climate Control
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: F 250 Super Duty Climate Control
    Posted: 17 Aug 2018 at 10:09pm
I have an '05 F250 w/5.4 engine.Strictly a work truck(no power ANYTHING) but does have A/C. My question is, regardless of climate control position;panel,floor,combo,defrost,defrost/floor whatever, the compressor activates even though the A/C mode is not selected. I can see it running in the defrost mode,but not in panel/vent/floor mode. Is this normal?? Yes, the A/C blows very cold in both A/C and MAX mode. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2018 at 10:18pm
I don't know if it blows in EVERY position, but FORD trucks do cycle the compressor in many of the selected positions..( my 2002 runs in 3-4 different positions ). Besides keeping the humidity down, you want the pump to get some on - off time and not set OFF for months at a time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2018 at 10:33pm
Thanks, my previous truck was a '95 Dodge and only recall the compressor running in defrost,A/C mode??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 1:03am
The compressor should run in all modes except floor and vent or off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 5:47am
sounds kinda normal, I know my 97 will run in max a/c, ac, vent/floor and floor modes. It might (should) be explained in the manual in the glove box.
it might be shut off( depower the clutch) IF you set the 'temp' knob high enough. I've never checked though.
Jay
This page was generated in 0.426 seconds.
