What Spool Valve For 400 Loader
chalmera View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chalmera Quote  Post ReplyReply Direct Link To This Post Topic: What Spool Valve For 400 Loader
    Posted: 17 Aug 2018 at 6:39pm
The spool valves on my 400 loader no longer work.  The checks leak and everything drops quickly.
What is a good replacement controller for the allis series 400 farm FEL?
Thanks,
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2018 at 8:21pm
Are you sure it's not the cylinders leaking internally?
Post Options Post Options   Thanks (0) Thanks(0)   Quote chalmera Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2018 at 8:33pm
The cylinders have all been rebuilt, they don't leak.  The spool valve/control/check springs/valves are shot.  Agco doesn't support it and a new replacement aftermarket spool seems to be around $300.  Just wondering if anyone had a suggestion.  I don't mind spending a few hundred for the right spool.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2018 at 9:11pm
A local hydraulic shop could probably rebuild yours.
nevans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nevans Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2018 at 11:53am
I used a cross on our 400 loader on our 17
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2018 at 1:10pm
I have a cross on my D17 and it works fine. We put a Prince valve on my cousins 190 with loader and it also works fine with no leaks.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2018 at 4:29pm
I have a 500 loader which was installed on our D-17 in 1972.
The valve bleeds off internally.
Which brand and model number  for a replacement?  Price range?
Post Options Post Options   Thanks (0) Thanks(0)   Quote chalmera Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2018 at 7:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote chalmera Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2018 at 7:02pm
Bump
