fairbanks morse magnito
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Topic: fairbanks morse magnito
    Posted: 17 Aug 2018 at 3:41pm
Anyone have info or can tell me where to find it on a Fairbanks vertical mount model Z 4B4B thought to be used on early WCs and MMs. need schematic and timing mark.
      Thanks Harold
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2018 at 8:00am
The only things I can find searching for Fairbanks Morse and Z are their hit and miss engine and a one cylinder Z impulse coupler.  Flange mount mags from Fairbanks Morse used on Allis Chalmers 4 cylinders were RV4B, FM4B, FMK4B, FMO4B, FMJ4B, and FMX4B.  And the B should be followed by a 3, as FMJ4B3 etc. if it was originally shipped to Allis Chalmers.  Could you show a picture of the mag?
Edited by TomMN - 18 Aug 2018 at 8:04am
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2018 at 11:52am
Here's a place where you can get the gears if the timing marks are worn off.
http://rebuiltmags.com/parts_Fairbanks-Morse.php
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 2:19pm
Thanks fella's I looked this up for a good friend and he said he appreciated it.
Harold
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 5:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 5:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 5:36pm
http://www.oldcroak.com/fmj-series-1942-bulletin-2856a/
If you paste the above site in a Google search, it works.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 7:00pm
He has a FMZ, Phil. I’m not familiar with it but I suspect that it times the same way.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2018 at 8:58am
When did the WC stop using the rv4 mag?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2018 at 9:03am
It probably depends on which engine was used at the time.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2018 at 10:37am
By the way that chart should be added to the information page.
It has excellent data that can be most helpful
Good Luck!
Bill Long
