TL-10 Wheel Loader Goodyear 3.00 x 7 tire Drive
Middlewest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Middlewest Quote  Post ReplyReply Direct Link To This Post Topic: TL-10 Wheel Loader Goodyear 3.00 x 7 tire Drive
    Posted: 15 Aug 2018 at 8:08am
I have a TL-10 with an over 2600's serial number,  and it started shaking badly and broke a motor mount.  When we started taking it apart,  there was a 3.00 x 7 goodyear smooth implement tire in a drum that drives the whole machine.  It is torn up and I need to find a replacement.  Thank you for any help.    All the manuals that I see for sale stop at Serial # 2502.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 3:03pm
i would call these guys, maby they can help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 8:06am
Motor couplings - used them on pumps up to 100 HP - was like a tire but made special for a drive where alignment was not perfect - flange attached to both shafts - then a ring bolted to flanges which anchored the rubber ring to flange.
 Might try Herc U Lift in Mpls as they were a AC dealer and still in fork lift business
Post Options Post Options   Thanks (0) Thanks(0)   Quote Middlewest Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2018 at 4:58pm
I have finally found a 3.50 x 7 heavy lug tire from Millers and we ground the lugs off and made it fit.  Thank you all for suggestions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2018 at 3:06pm
Clap
