Forklift mast bearings, may wish to inspect yours.
skyboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skyboy Quote  Post ReplyReply Direct Link To This Post Topic: Forklift mast bearings, may wish to inspect yours.
    Posted: 15 Aug 2018 at 4:58am
Had the mast carriage bearings fail on my lift..........thankfully nothing on it at the time. Really freaked me out. Forks dropped about 2 feet while up high!!
 I have a parts manual for my FTB 30-24 propane lift, finding the bearings was a real PIA.
Komatso who bought out Allis wanted $350 per bearing!!
 I allegedly have (4) coming now at $80, We'll see if they are the right ones and let you know
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 5:48am
Yikes.. how the heck does that happen ? Like, WHY did it drop ?? BAd enough I don't have great brakes now you got me paraoid about 'lift bearings'...
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote skyboy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 5:13am
Was raising it empty at about max lift ? boom the forks dropped to an angle cause the 2 top bearings failed, when I removed the carriage I saw the bottom 2 were shot also!!
 I have a platform that I use on he lift as a manlift, glad I was not on it when they failed.............probably would have fallen off the platform!!
Dswall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dswall Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2020 at 11:58am
We’re your bearings the correct ones? Mine are out and I was wondering where you found new ones. Thanks
Dustin in CA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2020 at 9:22am
Think at that price i would be looking at modifying cam followers to replace those bearings or making up some bearings from brass oil-lite bushings .
 Son bought a old fork truck and replaced bearings on bottom side with ball bearings on made up spindle shafts he turned on my lathe
