Model B tranny oil???
archangel_cpj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote archangel_cpj Quote  Post ReplyReply Direct Link To This Post Topic: Model B tranny oil???
    Posted: 12 Aug 2018 at 10:12am
39 B used for mowing with an woods... No hydros...   We still using 20wt oil or have we upgraded to something better???
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2018 at 10:23am
I'm using Super TRAC 303 Tractor Hydraulic Fluid in my B's transmission. Works fine. Tractor Supply has it in 2 gallon jugs for about $12.
Edited by BEK - 12 Aug 2018 at 3:52pm
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2018 at 3:52pm
Without hydraulics, you could use 80w90 or 80w140 or something in that range. However, I don’t see how 20w would hurt as everyone with hydraulics is running that or Hy-trans.
1951 B
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2018 at 4:00pm
I still use 20w.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2018 at 4:27pm
20 wt is fine... many use the hytrans / 303 since it is a STANDARD, readily available, cheap, and common to many tractor hydraulics and transmissions.
Gale Hawkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gale Hawkins Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2018 at 12:14am
303 was my choice just because that is what I run in the old Fords and MF and have it on hand. It is not cheap but I have been adding Archoil AR9100 and things are a bit smooth it seems but it is the wear reduction that interests me mainly and we buy it by the gallon for all of our engines so we have it on hand.
