For Hurst
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Topic: For Hurst
    Posted: 16 Jul 2010 at 5:04pm
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2010 at 9:07pm
That's a nice looking one.  The cab (along with the rest of the tractor) has really been taken care of in that one.  I wish I had the money to spend on it.  I'd just slide my HD front end under it and I'd have a heck of a cream puff for a 7000 then lol.
Hurst
1979 Allis Chalmers 7000
5800 Hours
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2010 at 12:21am
Hi Hurst,  Did you get your oil leak, etc. problems worked out?
I stopped in at Mt. Hope, Ks a few years ago.  Quite an impressive display of AC's on their lot.
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2010 at 8:24am
I'm working on the input shaft seal.  I have something that is causing the oil to be pushed past the input shaft seals after warmed up, as it has pushed all the grease I had between the seals (I installed 2 lip seals on the input shaft to make sure I had at least one on a good sealing surface).  I am cleaning all the powershift valves as we speak and will get those together Monday or Tuesday depending on when the parts arrive.  It only leaks after running for about 2-3 hours with the PTO on, but before that it doesn't even leak a drop.
Hurst
5800 Hours
