One Sixty Park Brake?
Macbeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macbeth Quote  Post ReplyReply Direct Link To This Post Topic: One Sixty Park Brake?
    Posted: 05 Aug 2018 at 8:21pm
I can not figure out how to set the parking brake. Does seem as it would be easy to find. I am assuming something is missing..
Where should I look?
Also What is the right side Heel pedal for?
Flyer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flyer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2018 at 8:38pm
Right side heel pedal is the differential lock.
The parking brake is an "L" shaped rod/handle on the left side of the transmission just aft of the clutch pedal.
An optimist sees the glass as half full. The pessimist sees the glass as half empty. The engineer sees a glass with double the required capacity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macbeth Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2018 at 10:02pm
Ok,
I have a bracket but no rod....
Looks like it is missing..
Thanks,
This page was generated in 0.107 seconds.
