Spin-out rim bolts?
Hunt4Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Topic: Spin-out rim bolts?
    Posted: 05 Aug 2018 at 4:35pm
I have 4 rims/ spin-out type and can't seem to break the 1/2" square head bolts loose to peice 2 good sets together, any trick to loosen these?
I don't have a torch set, I tried bolt loosening spray and a 1/2" impa t gun with no luck???
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2018 at 4:41pm
Dennis can show you how.
[TUBE]l2qXT3GGc5w[/TUBE]
Edited by CTuckerNWIL - 05 Aug 2018 at 4:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2018 at 4:49pm
If you can unbolt and remove the eccentric blocks one at a time, you can leave the wheel on the tractor. Depending on how rusted up things are, this may be the easiest way.
chalmera View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chalmera Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2018 at 5:55pm
Get a handheld MAPP torch.  20 minutes and all 4 will be loose.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2018 at 6:52pm
I have 8 that are loose and for sale!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2018 at 9:01pm
thanks ctuckernwil, I will give dennis's way a go tomorrow
John(mi) what do you want for the eight?
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2018 at 11:10pm
I sent you a PM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2018 at 11:57am
Here's how I've succeeded with mine!  Look for the Ted J posts....
Try this:
http://www.allischalmers.com/forum/wd-spin-out-cams_topic124006.html
Then this is even better...
http://www.allischalmers.com/forum/spin-out-rims_topic147710.html
Hope this helps!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2018 at 6:50am
Well I ended up getting enough of them free to rebuild my two CA Wheels on my new spinout rims .They actually work how they are supposed to once I put them together I tested them and they worked as they should, thanks guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2018 at 10:50am
I have done enough of these now that they don't intimidate me. But they almost always have to be take apart and cleaned and never seize added to the moving surfaces.
Glad to hear you got them apart and working again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2018 at 8:43am
Yep, definitely used never sieze on all parts as I put them back together.
wdtractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wdtractor Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2018 at 9:41am
I have a WD with spin out rims can you remove the spin out cams without removing the entire wheel off the tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2018 at 10:54am
I had to remove entire wheels and I used link that was shared title " Dennis can show you how and it worked great, hard part is freeing up small parts afterwards, ended up using entire can of PB and heated with my brother large torch that he uses to solder 4" copper...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2018 at 1:14pm
Yes almost always easier to remove the tire (unless its loaded and too heavy) and then unbolt the brackets and gently tap the wheel center with a 10 lb sledge from 5 feet above the wheel!:)
As mentioned the actual turning of the eccentric after removal may required a torch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wdtractor Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2018 at 12:57pm
I appreciate the information and your time,Thank You
Post Options Post Options   Thanks (0) Thanks(0)   Quote wdtractor Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2018 at 12:59pm
Thank You for the information and your time
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2018 at 7:54pm
I know the original post was for a CA (square head eccentrics) but for the WD and WD45 hex head eccentrics that are hard to loosen, I have a 3/4" drive 3/4" impact (deep) socket and this 40" - 3/4" drive breaker bar (https://www.northerntool.com/shop/tools/product_200668201_200668201) to break them free. I have never had one that didn't turn.
I spray a few times (over a couple days if possible) with Kroil before I try them and give them a good spray after they are off.
It has always worked for me.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2018 at 11:44pm
First off, Dennis needs a bigger hammer LOL! I have never had to swing my 16# sledge more than twice to get a hub to pop out! Also, I try to drive the eccentric back and forth (they will move 1/8" of more with the snap ring on), with a 2# hammer,  lots of PB Blaster, get them to move back and forth, then hold them on a 4x4 piece of wood with my foot and go after them with the 1/2" impact wrench.
ALLIS EXPRESS!
This year:
This page was generated in 0.316 seconds.
