What mower is this?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Topic: What mower is this?
    Posted: 05 Aug 2018 at 4:20pm
I acquired this sickle bar mower with a couple tractors I bought recently. I know nothing about sickle bar mowers. Any idea what model it is and what it fits? I bought it with a D-10, so I'm pretty sure it fits the D-10. What else does it fit? What is it worth?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2018 at 4:35pm
Nice mower, it's a 80R mower, fits any of the snap coupler tractors with the right brackets
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2018 at 4:40pm
Rear mounted mower
caledonian View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote caledonian Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2018 at 6:50pm
Cut many an acre with one of these. Yep it's an 80 R. We used it on a WD or D17.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2018 at 7:52pm
The attaching bracket appears to be for the CA, D-10 & D-12 tractors.
Looks to be in good condition.....like Mike says it will fit WDs, WD-45s, D-15s and D-17s as well with the right bracketry.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2018 at 7:54pm
The mower attaches to the tractor via the mower mounting bracket that replaces the draw bar support on the tractor. This is the bracket with the large dia piece with the smaller pins sticking out from the ends. It is lifted up by the snap coupler on the right side of the rear lift arms. If the Mower mounting bracket fits your tractor, you should be good to go. PS; looks to be in good condition, if so, you will enjoy using it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2018 at 9:04pm
Yea that's the mower that I also started mowing hay with on our D17. Which both came new through my grandfathers dealership.
There was only one thing that dad stressed to me when using it. Do not put you fingers into the teeth, or blades, or guards when you lift it to fold over to transport possision
This page was generated in 0.199 seconds.
