WD starter
crawdon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote crawdon Quote  Post ReplyReply Direct Link To This Post Topic: WD starter
    Posted: 04 Aug 2018 at 1:42pm
Try to start WD turned over two or three times now kills the gauge and battery cables get hot but doesn't turn over or spin the starter any suggestions
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2018 at 7:38pm
Stater could be locked to  flywheel starter ring gear, remove starter and bench test it to see if it will run.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 11:03pm
did the starter ever work ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2018 at 2:25pm
First, remove the ground cable from the battery. Take the starter out and check it out. With the starter out, check that the engine is free turning by putting the crank on it and roll it over a couple times.
  Things can get worn enough to let the gears climb each other and lock up. Mice can also build nest so thick it will wind up in the starter and ring gear, and lock things up.
Edited by CTuckerNWIL - 07 Aug 2018 at 4:48pm
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2018 at 4:38pm
Good heavy cables shouldn’t get hot. Can you read the gauge of the cable stamped in the insulation? If it’s getting hot it is dropping too much voltage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2018 at 5:24am
Hot cables mean big time amp draw. Could be Starter needs a rebuld, cables to light, bad battery, dirty connections. Cable size should be 1 gauge or larger if running 6VPG. If the Starter is dragging, probably needs a rebuild. We offer Starter motor rebuilding the correct way if interested....
Steve@B&B
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2018 at 6:53am
All good advise above and Steve is your man for rebuilding them. Thumbs Up
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2018 at 7:30am
Kills the GAUGE?
Sounds like the gauge wiring has become a better return path than something that's supposed to be the return path...
Cables get hot for one of two reasons-  they're carrying too much power, or they're too resistive.  With my prior sentence as reference, I'll BET you've got a bad cable...
