Help with WD45 diff tranny gasket replace
Duane Becker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane Becker Quote  Post ReplyReply Direct Link To This Post Topic: Help with WD45 diff tranny gasket replace
    Posted: 21 Jul 2018 at 9:31am
I have a 1955 wd45 with a gear oil leak at the differential and trany. I have decided to pull the diff and trany apart and replace the gasket. I have removed the back tires, the drawbar, battery and box, disconnected the brake lines, hand clutch and various other small items that would prohibit the separation-haven't disconnected the steering wheel mount, but it looks as if I need to as well.
My questions are: What is the best way to pull the diff and trany apart. I would like to attack it from the back end-diff end. If I pull the two apart, I assume there will be a shaft, will anything be falling off the shaft as I'm pulling it out? I have a cherry picker, jack stands and a knowledgeable helper-I'm not that mechanical. Any suggestions and help would be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2018 at 10:41pm
I would put the back tires back on, support front part with a good stand then role the back end away with a floor jack under it.   MACK
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 9:44am
Like Mack said put the wheels back on or build a roller stand like this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane Becker Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 6:41pm
Thanks guys for the post and pixs! This will help. This coming Friday will be another work day. I'll keep you updated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 7:10pm
I forgot to say, keep the hand clutch engaged so the disks don't fall down and watch the trans input shaft stays in the front of trans as you roll them apart.
Edited by Don(MO) - 22 Jul 2018 at 7:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane Becker Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 10:16pm
Thanks Don, I probably would have left the hand clutch disengaged! I'll make sure it in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane Becker Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2018 at 6:17pm
Just finished up on the gasket replace. Everything work good and the differential rolled pretty easy away from the transmission. Forgot to take the two bottom bolts out of the transmission at first, but discovered them shortly after. Rolled it out cleaned up the two services good and then applied the new gasket. Went back together ok. Had to keep adjusting the height of the differential, but it when in after a few minutes. Good learning experience for me. Thanks to all who posted and especially to Don for his expertise and advice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2018 at 7:08am
I hope the phone call helped.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane Becker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2018 at 9:32am
I've also got a gear oil leak on the PTO, not at where it bolts to the block, but where the PTO shaft connects-for quick reference here is AGCO parts diagram:
Leak is coming from the #2 Case in the diagram. My wd45 is a 1955 s/n 208883, and AGCO diagram mentions #3 oil gasket replaced slim after s/n 24082. So would I need that gasket replaced, along with the oil seal #1-or just the gasket?  Or anything else? Is this an easy swap out gasket and seal project? Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane Becker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2018 at 11:00am
I just checked that link to AGCO may not work, but its under the Drive Train Power Unit 240 page that I'm referring too...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2018 at 6:41am
Here's the parts list from AGCO, one 70227237 gasket, two 70224779 seals, (Yes you need two of them to replace the one old one for the box out put shaft seal) I always get three of 70224655 gaskets (you might not need all three but get them just in case you do) one 70224642 seal this sela is for the shifter shaft, (change it to)
Edited by Don(MO) - 05 Aug 2018 at 6:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane Becker Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2018 at 9:00am
Thanks Don, I'll order all three gaskets tomorrow morning...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane Becker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2018 at 2:23pm
Don has helped me with this in a previous post above, and others are welcome to jump in here.
I have a gear oil leak on my pto. Its not where it connects to the block, but rather at the area where the pto shaft comes out to the back of the tractor. The pixs show the pto case that I removed from the tractor. It leaks behind this case. Notice mine has a steel shim. Looks like it leaks at the shim and not the cup and cone bearing Agco Part numbers 3 and 4. Don you gave me the gaskets and items in the post above. Looking at the pix here and my description, do you still think I need the gaskets you mentioned? Should I replace that metal shim with a regular gasket?
Edited by Duane Becker - 08 Aug 2018 at 4:37pm
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2018 at 3:03pm
You need the shims to get your bearing tolerance correct. I figure out the correct number of shims then lightly coat each side of each shim with some #2 permatex. So far mine hasn't leaked in 6 years.
Edited by Allis dave - 08 Aug 2018 at 3:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2018 at 3:07pm
A-C used a thin .005" ??  paper gasket between each and every metal shim so oil didn't drip from the PTO box. There is no other way to seal that output bearing cover.  If you don't have a paper gasket, any kind of RTV or Permatex will do, but remember, you are setting your rolling torque on your PTO output bearings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane Becker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2018 at 4:30pm
Thanks for the reply, after closer inspection, and looking at the parts diagram, looks like there is an oil seal at the very front, you can see it in the pix. Probably should replace that too?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane Becker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2018 at 4:35pm
Sorry forgot to include pix:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2018 at 6:57am
You should replace now or you could take everything apart again and replace it later. I vote now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2018 at 9:08am
Call me before you do more work on it.
ruwetyet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ruwetyet Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2019 at 7:34pm
I'm in the middle of tearing my PTO down for fluid leaks.  There are 2 metal shims.  Just to confirm, I should put a paper gasket between each?  And can I reuse the same shims provided they are in good condition?
Lastly, can someone explain the significance of these shims and how to determine the actual spacing necessary?
This is my first tractor, want to take care of it.
WD45 Gas
Thanks!
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2019 at 8:21pm
Shims set bearing clearance.You don't want any play and also not too tight. I would say a slight drag when turning by hand would be about all you want.
TimCNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2019 at 11:37am
Metal shims are no longer available, so take very good care of them. The paper gaskets/shims (P/N 70224655) are available at Sandy Lake Implement, $4.08 each. I'm just doing mine now, too. Mine has 4 metal shims, so it needs 5 paper to "sandwich" them. I just use Permatex Copper spray, seems to have the least affect on thickness, and it was recommended by Bill at SLI.
At first I thought I only had 2 metal shims, then they separated into 3, then 4 lol... so be careful. Fragile/delicate parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ruwetyet Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2019 at 7:12pm
Thank you guys for the guidance and information.
After further inspection, I did have 3 shims and carefully separated them.  I'm soaking them now so the old paper between them comes off easier.  North Central AG has gaskets for $3.07, Gearbox Gasket for $2.60, Output Shaft Seal for $11.60, and Shifter Seal for 16.60.   Hope to get them on the phone tomorrow and order.
I do have 1 challenge ahead: the hole in the output shaft for the shear pin has mushroomed out and evidently wallowed out the ID of the extension shaft creating an undercut making it impossible to separate the two.  I don't want to pry too hard and break the cover, so i think I will have to dremmell the mushroomed area to allow clearance.  It's tight, but I don't see ant other options.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2019 at 8:02pm
ruweyet,
 I had same issue and had to pry the collar off of the shaft. Found a better output shaft in a parts WD. They were very tight!
You guys are right into these old WD's ! Great!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ruwetyet Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 5:53pm
The goodies have arrived!  Those gaskets between the shims sure are thin.  I have talked myself into a sand blast cabinet.  Wire brushing is for the birds!!
