Home A/C Question
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: Home A/C Question
    Posted: 19 Jul 2018 at 10:07pm
We have two A/C systems for our house, and both are 26 years old (I think we've been lucky). They have been trouble free all those years. The outside condensers are Trane, and they are identical units (consecutive serial numbers in fact). The problem now is one condenser makes an awful racket when the fan shuts off. It starts up perfect and runs great, just purrs and barely makes any noise, until it shuts off. Then it makes a racket like you threw a large tree branch into the rotating fan. At times when I've been out in the yard and heard it make the noise, it's made me cringe.
The other condenser runs just as it should, and when it shuts off, it does so quietly.
I've looked at the problem condenser, and nothing appears loose or out of the ordinary. It's nice to have an identical unit to compare it to, but so far it hasn't helped find the problem.
Any ideas?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2018 at 11:51pm
fan loose? bad bearing?
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2018 at 6:00am
 Ditto what ole Shameless says,,,must be the change of motor RPM that indicates a bearing in motor or fan,,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2018 at 6:14am
don't know how a 'bad bearing' could create the noise but...
perhaps a fan blade has lost a rivet or two ? Saw a post here about a tractor losing part of a blade ($$$ to the rad !!)
Whern inspecting be SURE to power off the units !! Pull the disconnects next to them. You don't want one of them powering up when you're in them. The fan won't kill you, but the scare will jolt you, you'll fall back, trip over the wheelbarrow and land into the smouldering firepit...
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2018 at 6:51am
If you can get your mitts on the fan like unscrewing a shield, I would go hands on and rotate and shake the blades around to check them and look for a bad bearing.
circuit breaker off of course.
BKarpel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BKarpel Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2018 at 7:45am
Check out the fan blade. I have seen some where the pressed in hub gets loose and the fan starts slipping. Sometime it gets so bad the motor no longer turns the fan. They make all kind of wired sounds then. You can pull the top off the AC and check the bearing for play. You can buy a new condenser motor and replace it fairly easy and reasonable your self if needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2018 at 9:02am
 ""  don't know how a 'bad bearing' could create the noise but...""
     TSK,,,,TSK,,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2018 at 9:38am
I'll check that out this evening. I figured if it were a bearing, it would make some kind of noise all the time, but it just starts up and purrs real quiet when running. Only when it shuts off that things go "Bang!"
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2018 at 10:15am
Had an old chest freezer that made banging noises when the compressor shut down. It turned out to be loose mounting bolts.   HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2018 at 10:53am
Agree with chaskaduo.  They don't make noise powering up because of the pull, but when they are shutting down they tend to vibrate more, thus the shaking of the mounts.
See ya in a week buddy!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2018 at 2:27pm
I'll check this all out.
See you soon, Ted!
Hopefully the A/C doesn't crater...it was 112 degrees yesterday, and will be hot again today. I'm ready for a little northern escape!
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2018 at 8:16pm
 I've had grinders and other motors get obviously louder when shutting down that turned out to be bad bearings,,,then again,,I've had em be rattling while running so take your pick,,, By the way,,,,,Good Luck, CrestonClap
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2018 at 9:00pm
Well I didn't get to it today. I had another project staining a deck/porch and that took longer than I thought it would. It is next on the list of things to repair around here, though. Have something scheduled at my grandparents' place the next couple days, so may be Monday before I can get to it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2018 at 9:09pm
grab an old 190XT fan, mount it on a pulley, run one of them long belts off the back of your 66 combine, puts it on an electric motor off to the side, can make a belt tightener outta yer ferd tractor!
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2018 at 7:00am
 UMMmmm,,,,,UMMmmmm,,,Shameless,,,uhm,,,seems as if they is something missin on thet contraption you is suggesting,,,,,oooops,,!!    forget it cause you prolly WILL add more stuff to it just to throw ole Creston a curve,,,,,LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2018 at 7:39am
Is it kinda like the snow machinimo? Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2018 at 8:24am
Now Shameless you really expect that Ferd to hold up against that kind of "tension" in the summer heat??? Lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 12:47am
well...you might hafta tie that ferd to a tree!
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 8:07am
has anybody actually seen Shameless and Red Green in the same room together?
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2018 at 6:12pm
LOL Big smile Clap Shocked Thumbs Up  GOOD one Lou!! LOL
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2018 at 7:13pm
Pull the disconnect remove the cover from the side follow the fan wires and unplug one wire secure it so it won't touch now put disconnect back in and let it start and run a couple min then turn off this will tell you if noise is fan or compressor
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2018 at 8:55pm
Did this this evening. I'm thinking it's in the compressor now. When turned off, it shook a little and made the noise. I don't know much about A/C, so I may just need to get a pro in to swap it out. I'm guessing they have to "catch" all the old Freon when unhooking the compressor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2018 at 10:02pm
at 26 years old............ might be time to look at an upgrade system ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2018 at 11:45pm
If it's R22 it's not worth putting a compressor in it we charge $100 per pound for 22 roughley ,700$ for ref 4-6 hrs at 100$ per hr and cost of compressor and not much in warranty if it's just noise letter run and start saving up for replacement of the system
Grayray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grayray Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2018 at 5:38am
Hate to be the bearer of bad news, but at 26 years old, I think you are fixen to write a check for about $5000.00.
This page was generated in 0.665 seconds.
