carb cleaner
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: carb cleaner
    Posted: 16 Jul 2018 at 8:08pm
what do you guys use for soaking carb parts when rebuilding? I have been using an over the counter carb cleaner (don't remember off hand, the brand) but I just am not happy with it. Im not convinced it's getting the crud out of the teeny tiny ports
I am still confident of this;
Wait for the Lord;
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2018 at 10:00pm
Berryman Chem-dip. Not what it used to be with EPA regs but still does the job just takes a little longer soak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2018 at 11:47pm
would brake clean work?
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 6:59am
 I got this from YouTube and it does work great. Use Lemon juice and boil the carb parts in it for bout 1 hour. It leaves a grayish film on parts that comes off easily with water. I went to Dollar Tree and got two quart bottles for $2.00,,,,like I said,,it works great,,,,,,,Clap
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 2:55pm
X2!
I use that method, and the Berryman method. Both work. The lemon juice method is cheaper, though.
I used the Berryman method on a WD45 carburetor. Let it soak overnight, and the next morning the whole thing was stripped clean.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 5:10pm
(MEK) methyl ethyl ketone, acetone, and gas is a pretty potent mix. Should just about dissolve anything in the carb. Keep sealed, very high VOC's (volatile organic compounds) involved. Use in well ventilated area very flammable. Wear gloves, avoid breathing. I use to do environmental crap for a printing company where I worked after I hurt my back.
Edited by chaskaduo - 17 Jul 2018 at 5:12pm
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 11:37pm
i like to put them in a metal can of plain e10 gasoline for a day rinse and blow then to the ultra sonic cleaner for an hour at 150*
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2018 at 12:27pm
I'm gonna have to try that lemon juice one!!
Regular carb cleaner is getting pretty expensive.
This page was generated in 0.367 seconds.
