Allis HG Any good |
Post Reply ![]() |
pinball ![]() Orange Level Access ![]() Joined: 28 May 2014 Location: missouriu Points: 6405 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Jul 2018 at 7:03am |
Theres a local sale with an allis hG track loader on the list. JUST wondered how hard parts areto find for it and how good of a machine it was when it came out and if oher allis crawlers machines parts will transfer, thanks norm
CAL(KS) ![]() Orange Level ![]() Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
what is an HG?
Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, 2-S77, HD15 |
I meant 6g. sorry about that
gemdozer ![]() Orange Level ![]() Joined: 17 Sep 2009 Points: 1058 |
The hd6g is good machine and the track can be found but not easy and for the other parts they are easy to found.
HD6GTOM ![]() Orange Level ![]() ![]() Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
I had some. The later ones are a little better than the early ones. Later ones had a bigger crank shaft, mine seemed to start real good. I know the later ones had a decelerator peddle, helps when loading trucks. Later ones had more rollers on the tracks. Mine were very dependable. If you ever put a main clutch in one, be sure to adjust the clutch brake. The last one I had, I bought it with a "bad injector pump". The guy lied to me, it ran on 3 cylinders, it had a hole in the block behind the pump. I picked up a motor out of a late hd6 crawler. It was quite a bit higher HP than the old motor. Would easily spin the tracks.
Post Reply ![]() |
