WD 6 volt not charging
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Topic: WD 6 volt not charging
    Posted: 15 Jul 2018 at 12:06pm
here's what is happening,, when I ground the panel box (its supposed to be grounded, right?) I get arcing and the resistor on the light/charging switch glows red hot. Amp gage will show discharge when light is turned on, but will not show a charge,, cutout relay is not making contact when engine is running,, I can close the contacts (Yea,,, I know that is a no-no) and amp gage will show charge. still POS ground.  charging system was working, then after setting for a few months, did not work. Autolite genny if that makes any difference
Is the genny running the wrong polarity? I'll try polarizing...
maybe a bad amp gage or light switch? short, grounded?
broken or shorted, grounded, wire somewhere?
bad cutout relay?
I will keep searching,, but other input is welcome, might tell me something I have not looked for...
I would like to keep/fix the 6V system,, so don't suggest 12V alternator but, that may happen if this cannot be fixed
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2018 at 12:38pm
Was the wiring changed? This smells like a wire with 6 volts got shorted to the F terminal or the wire attached to the generator F terminal. There could be an internal generator short, I suppose. Disconnect the F terminal at the generator and see what happens. Did the two wires at the generator somehow get switched?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2018 at 4:05pm
Ok...its working now...I put a D-R genny on off a parts tractor.just cleaned it up, shined up the commutator, charging about 5-6 amps, 10+ amps with the lights on or hi charge position.wiring is original, allthough lotsa black tape on it
I'm thinkin there was a short or ground out in the other genny...
Edited by Michael V (NM) - 15 Jul 2018 at 4:06pm
