All Crop Drill
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Topic: All Crop Drill
    Posted: 15 Jul 2018 at 8:21am
Local show coming up first weekend in August so I'm trying to get some stuff cleaned-up and ready for display. Once mounted on the WD I realized the need for a little weight on the front-end, and that completely empty! Had a pair of front wheel weights painted so on they go. Don't know how the paint got so beat up all they have done is sit in my basement. Used some of my home-made bolts to mount them.
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2018 at 8:41am
Looks good. I like seeing implements with the old tractors. Makes the shows more interesting.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2018 at 10:07am
yes, looks good...
that's one of the implements that I would like to have...
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2018 at 2:49pm
Great looking set up and drill!!
Have a drill just like it. I have used it probably 4-6 times now. Always seem to forget the correct way, in which the chain Zig Zags around the sprockets to hook up to the tractor wheel.
Have busted a few chain links because of it, and always swear I am gonna take a pic of it the right way and leave it in the seed box of the drill LOL
Oh well.... Keep those antique implements spinning!
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2018 at 8:24am
Don, I did the same thing with the chain! Then I found out that old flat chain is tough stuff! Need to find out if something is stuck or it was just improper routing that caused the problem. It will be fine for display at the show but I want to use this thing next spring on some waterways.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2018 at 8:35am
Nice set-up.  It's always nice to see implements at shows.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2018 at 8:48am
Spent the weekend cleaning up and getting ready for the show. I would really like to take the 185 but don't have a trailer big enough to haul it and it's been having a bit of a fuel issue so roading it 30 miles one way is out. Hopefully get to do a little plowing with the wide-front, Have always used the narrow in the past. Took a pic of them all lined up for the power washer. First wash for the CA, and it needed it!
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 8:04am
I really like all your AC collection. Whats wrong w/ the fuel system on the 185.  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 8:59am
Nothing serious, just need to pull the tank and give it a good cleaning. Keeps clogging the sediment bowl. Of course the tank is near full!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 3:05pm
Is the show you're talking about the one up by Marshalltown?
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2018 at 8:53am
Yes. The Mid Iowa Antique Power Association show, August 3,4,&5. AC is the feature tractor this year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2018 at 3:00pm
I guess I better add this one to the list then...
REEDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REEDE Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2018 at 7:38pm
I like the line up. You got some great looking machines.
This page was generated in 0.266 seconds.
