Dirt Scoop Parts
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Topic: Dirt Scoop Parts
    Posted: 08 Jul 2018 at 12:33pm
I bought a Allis dirt scoop over a year ago. Just now getting around to working on it some. Looking for some parts. Found a manual online and ordered it. Need the pieces that connect to the tractor lift latches. All it has now is a piece of chain with a bolt. Also this one doesn't have a bracket to hold the trip rope up. It doesn't have holes drilled for one either. Was there different versions? Thanks.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 1:03pm
I think there was two versions. One that faces forward and one that faces rear.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 1:55pm
The bucket on mine is facing tractor. But I think it's reversible? Not sure waiting on manual to show up. Really would like to find the pieces I am missing for hooking it up properly.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 2:42pm
I think ive got a couple dirt scoops for parts, probably have the pieces you need.
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 4:19pm
They are reversible.  I have reversed mine to see how it fit.  Currently the bucket faces back.
SLB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLB Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 9:53pm
I have a dirt bucket as well.    I can send pictures of the release mechanism.  It does not have the pole but rope works good. I would love to have a pole made for it, or better yet,  buy an original if there is one to be bought. :)  Anyway if you would like a picture, P.M. me and I will text you the pictures.  Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2018 at 9:00pm
Manual came in today. This model doesn't have the extra piece to hold trip rope up. I just need the correct pieces to connect to tractor lift arms instead of a piece of chain and a bolt. I'm wanting to get it painted and take it to a show with tractor.
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2018 at 11:58pm
Yes, they are reversible. I've used mine both ways. Mine is just missing the stand, but I guess if a person keeps it hooked up all the time and uses it the stand isn't necessary.
Have fun with it, I sure do. Great for all kinds of work. I mostly haul wood with mine though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2018 at 1:01pm
I also need a pin. One is missing.
Joe in Manty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe in Manty Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 10:12pm
I picked up one of these in spring as well. I've got it on my D15. I was looking for a manual. Blake, where did you find a manual? Plan on looking for one at Hutch next weekend.
Joe
Dad's '52 CA, '68 One Seventy
My '61 D15
