89 gmc performance
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Topic: 89 gmc performance
    Posted: 07 Jul 2018 at 3:53am
So customer dropped of his 89 gmc 2 wheel drive pickup with the 350. It run but very poorly. It almost seemed to be flooding it's self. Well I figured it might be the coolant sensor. So I let it sit until I had a little time to go screw with it which was about 2 hours. Well that pickup would barely run now it was bad enough you couldn't put it in gear or it would die.
Well I decided to peak under the cap. Woof that looked terrible. So new cap, rotor, and ignition module. Put it together, reached in and hit the key and it fires right up. It runs but not well. It has a miss to it but hey it runs on its own except if you try and give it any gas it will fall on its face again like it's flooding.
I run out of time to screw with it. So today I bust out my multi meter and do some poking around. The coolant sensor does test good. Injectors test well.
Where shall I go from here. A guy in town whom I trust said the fuel regulator.
Is there something I'm over looking here. Now that it runs it runs a bit rough. It will run at idle on its own kind of. It's more of a sloppy idle where it's always hunting for a good idle speed. It revs up a bit then it will start slowing down until the computer kicks in and speeds it back up. If I try to speed up the motor it starts to cough and stumble like it's flooding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 5:51am
honestly that's what Goggle is for...
I'd try '1989 GMC rough running' as keywords,see the 1,000s of hits that come back.
two things though
1) replaced all the plugs ?
2) replaced all the fuel filters ?
 maybe a bad fuel pump ?
OK, that's 3....
Jay
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 7:06am
Map sensor, EGR stuck open?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 8:06am
I should have mentioned that I had the egr off and it moves good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 11:08am
If the fuel regulator diaphragm is leaking/torn I would think you would have some fuel dribbling out of the injectors after you shut it off. I think fuel pressure for TBI is 7-15 psi.
The 'hunting at idle' means something is wacking the PCM and trying to find a happy medium.
You could down the throat of the throttle body and see if it sucked in the throttle body gasket. They were bad for that but doesn't generally cause the problem you describe.
Check the vacuum to the map sensor, if is leaking or no vacuum the PCM thinks it is at full load. Same with the EGR solenoid if it's bad.
About all I got.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 3:19pm
an O2 sensor can't cause that kinda trouble can it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 3:23pm
Is the 'engine light' ON? If so, get the scan code.....it'll 'point' NOT telll you where the problem is, maybe,hopefully...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 5:26pm
Throttle position sensor?
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 6:42pm
My 88 suburban ran horrible when I bought it. It would toss a o2 code but nothing else. I changed the coolant temp sensor that helped some.follow all the plastic vacuum lines and replace any that are suspect. Tha TBI is abigimprovement over a carb but the OBD1 dosent help when trouble shooting. It's kinda stupid and soft faults reset themselves without keeping a record of it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 6:51pm
Take a squirt bottle with water, spray around Throttle body base and intake check for vacuum leaks. Use water not gas and not carb spray, old lesson from twenty years ago plus.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 7:15pm
what you decribed sounded like one of my vehicles years ago....was a parcial flat cam
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 9:19pm
Have you checked the timing?
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 8:05am
I second HubertGA's suggestion, throttle position sensor.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 9:15am
My 77 chevy pickup with a new 350 in it couldn't pull an average hill without down shifting. A mechanic friend told me to take the battery ground cable that went to the alternator bracket and put it on the bolt that holds the bracket on the engine block for a better ground. I couldn't believe it but that solved my problem. That taught me how important it is to keep all electrical connections clean!
Edited by nella(Pa) - 08 Jul 2018 at 9:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 9:42am
I have not checked the timing for one simple reason. He said this come on all of a sudden. Which to me I would lean to a bad sensor. Maybe I'm thinking wrong about that.
Tomorrow I'll build a jumper harness so I can check the throttle position sensor.
I did try a different map sensor that I had sitting on the shelf. It was used and I hope I didn't keep an old junk sensor. But any way that didn't help.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 12:17pm
My first thought as well. They were notorious for that
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 3:17pm
Take the Neg cable off the battery for awhile.  When you reconnect it that should reset any faults.  And like was mentioned,a good ground to the body and the engine.
Steve M Ind View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M Ind Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 8:18am
Cracked magnet on the distributor shaft will cause to run bad. Pull the cap back off and check real close with a flashlight for a crack on the magnet usually at a rivet that holds it together. only fix is to replace the shaft as the magnet is made part of it.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 10:58am
OH the good old days,flat cams,the early carbon wires that the insulation would crack on or the carbon itself would break. All good fun.
Good luck in this case luck can save a lot of time and parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2018 at 12:42am
Well guys... I tested the throttle sensor and found that good.
Then changed the fuel regulator. I did get it to run on its own but still very very poorly. As I was screwing with it this whistling noise kept bugging me. It sounded like a massive vacuum leak. So I went and got some brake cleaner. I know I know it's against your guys advice. I started to spray around the base of the injection module and the intake. By gosh I found my problem.
Got a gasket coming in the morning. I'll let you know how it turns out.
This page was generated in 1.000 seconds.
