WANTED !!
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Topic: WANTED !!
    Posted: 05 Jul 2018 at 6:05pm
Need  HD5 B   parts , out  put    Splined  shaft   with U-joint  &  end  yoke ..  Part  number  065481 .
  Also   recoverd  or  excellent   seat bottom  seat  back  &  sides   for  same ..
   Thanks  Tony          877-602-3994
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2018 at 6:31pm
Check with General Gear, in Idaho, may have some of it.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 7:37pm
you will be lucky to find a good one as they all wear as they are not lubricated. on a fair one I have on mine I drilled and tapped for a grease fitting and lube it occasionally. it will prolong the life and take up a little of the space that is worn.
This page was generated in 0.168 seconds.
