56 allis b
gman11110 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gman11110 Quote  Post ReplyReply Direct Link To This Post Topic: 56 allis b
    Posted: 04 Jul 2018 at 8:47pm
I restored a 56 b. Cant seem to get front main to not leak. I have the timing cover centered. Put a new seal and still leaks. My seal is a lip seal without the spring. Do they have a double lip seal with spring that fits. Any help please
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2018 at 10:01pm
the original seal was leather and there was a spiral groove in the shaft to pull a drip onto the leather........If the groove is still there, you have to clean it out and fill with JB weld and sand smooth, or get a " speedy seal" which is like a .003 thick stainless sleeve that you  press over the shaft... Your rubber seal should have a spring.. I though all of them did. Normally you press the seal into the housing, then slide the housing over the shaft. The seal centers the housing while you bolt into place.
