Roto-baler operating
560Dennis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 560Dennis Quote  Post ReplyReply Direct Link To This Post Topic: Roto-baler operating
    Posted: 30 Jun 2018 at 9:51pm
Does the roto baler have to stop every time to unload a bale?
Been awhile since I've seen one run .
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2018 at 9:54pm
Yes.  That's why the hand clutch was so important back in the day.  Had to keep the PTO running when the operator stopped to unload the bale.  I remember an arm at the top front swinging from one point to another that signaled the operator to stop and unload the bale.  Never was around one of the Roto Balers with its own motor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 560Dennis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2018 at 8:37am
That would be tiring for me with out independent Pto and foot clutch then.
Krazy Karl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Krazy Karl Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2018 at 11:21am
The conveyor should stop then the twine arm about same time should drop and tie bale.
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2018 at 12:34pm
Dad purchased a new Allis roto baler on June 29/50 and operated the baler with a WF.
when the arm dropped push foot clutch in , put tractor in neutral tie bale , then put tractor
in second gear go until arm drops again - was still better than forking loose hay onto the wagon by hand.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2018 at 4:56pm
If I'm not mistaken, was there a model Rotor-Baler that had a feature that allowed non stop operation? Kinda like a extra tray that would continue to gather the hay while it was tripping and ejecting the bale?
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2018 at 5:04pm
that was known as a model 10
D17Milo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17Milo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2018 at 8:47am
I remember when I was a kid we had a neighbor with a 2 cly. John Deere, he talked about pulling the clutch back , putting it in neutral, clutch forward, bale out, clutch back and back into gear and the repeat the process.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 560Dennis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2018 at 9:08pm
I don't know that much about theses balers ,but I remember seeing the bales left in the Fields here..
Question is why did they need string knotters ? The twine would rot wouldn't it ,or mice would eat it ..
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2018 at 9:43pm
They didn't have string knotters, just wrapped string multiple times around both ends.    MACK
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2018 at 9:35am
In our picking up bales... we were the knotter...had to take the loose end ( the baler 'knotted' the first end) and slip it under the twine at least once and yank it to knot the final end of twine... took a couple of seconds but saved many a bale from "unwinding" when being handled.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2018 at 10:07am
[QUOTE=FloydKS]In our picking up bales... we were the knotter...had to take the loose end ( the baler 'knotted' the first end) and slip it under the twine at least once and yank it to knot the final end of twine... took a couple of seconds but saved many a bale from "unwinding" when being handled.
[/QUOTE
They will only unwind one way think its the side that the twine starts on first to your left put it on your right and they won't unwind no need to tie.Think I got the sides right been a long time but I've handled thousands of them.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2018 at 10:44am
They actually had a tool to push the end of the last wrap of twine down into the bale. Looks like bale hook on one end and a needle on the other end. Even had a special storage spot on the baler. I don't have the baler any more but do have the tool.
Leon B Mo
