28% Nitrogen applicator HP requirement
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Topic: 28% Nitrogen applicator HP requirement
    Posted: 27 Jun 2018 at 9:05pm
No-Tilled corn for the first time this year. Would like to apply 28% for the first time. My elevator has only 12 row applicators. Will my 200 be able to pull this on flat sandy ground? Thx
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2018 at 9:48pm
Yes
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2018 at 9:52pm
Maybe
If you have decent loaded tires and no huge hills you will be fine. We pull a 11 knife with a 6080 you just need to think. When we had the 7000 on it with empty tires I really had watch the hills.
JarrodACFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2018 at 11:06pm
I'd say it would be no problem. We pull a 30' applicator with an 85 PTO horsepower 2wd New Holland (10,000 lbs, no wheel weights or fluid), and don't have any problems at all. We pulled the same applicator with a 185 for several years, just a little slower. You'll have no problems at all.
Edited by JarrodACFan - 27 Jun 2018 at 11:07pm
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN
wayne IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayne IA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2018 at 12:16am
Only problem I ever had pulling a nitrogen applicator with the 190 XT is when the Coop thought it was a good idea to put a hydraulically driven pump on it and a Raven controller that needed a closed center hydraulic pump to work correctly.  Otherwise the last rental unit I used from a different Coop was no issue for pulling the unit (had a ground drive pump), the only thing I was concerned about was how much weight it was putting on the hitch since the design was very tongue heavy (so I didn't fill the 1000 gallon tank, just 600-800 gallon).  That unit though was a 16 row with the wing tips folded up to make it a 12 row.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2018 at 1:17am
I pulled an 7 knife with my 180
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2018 at 7:24am
Are they "knifes" or disc openers? Would think that could make a difference??
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2018 at 8:19am
Most 28% applicators are not hard to pull. The applicators usually has coulters or coulters followed by a knife. The knifes don't run very deep and the applicators themselves might require more hydraulic power than drawbar.
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2018 at 9:57pm
This page was generated in 0.202 seconds.
