Need help...early style gov-injector rod linkage
JamieH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JamieH Quote  Post ReplyReply Direct Link To This Post Topic: Need help...early style gov-injector rod linkage
    Posted: 26 Jun 2018 at 4:15pm
Need help locating the linkage rod from the governor to the fuel injector control arm...it's an early style 2-71 on a 49 hd5...thank you for any guidance
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2018 at 3:16pm
I have the fine rod connect in governor to the control injector with adjustement  piece and she is approximatif 10 inch longue
Post Options Post Options   Thanks (0) Thanks(0)   Quote JamieH Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2018 at 12:57am
I believe that would be it...according to the parts catalog the part number would be 5154414. As I understand, it is an early style governor but could be wrong...I have had all the linkages off and apart to clean them so they can have full range of movement and had apparently misplaced that one. How much you wanting for the one you have
This page was generated in 0.123 seconds.
