allis chalmers hd7g
david weldon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote david weldon Quote  Post ReplyReply Direct Link To This Post Topic: allis chalmers hd7g
    Posted: 17 Jun 2018 at 4:38pm
an allis chalmers hd7g I purchased .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2018 at 6:11pm
Appears she had to be recovered!! In a spot?
HD6GTOM View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2018 at 6:47pm
Good luck with her. Please keep us posted on her.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2018 at 11:40pm
Very cool picture!  You have already more then doubled it's value getting it home.  The truck (Lory) is pretty impressive too.  I like the stadium lights on the top of the cab!  Keep us posted with more pictures and info as you get the machine operational.
Allis Express participant
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2018 at 7:12am
Congratulations on the new addition. Great recovery.
HD16DC, Bobcat 863 Turbo, Oliver 1855, John Deere 855,
Post Options Post Options   Thanks (0) Thanks(0)   Quote david weldon Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2018 at 3:13pm
hello dave I picked it up in northern Ireland in omagh county tyrone and took it back to county meath in southern Ireland where I live the reason why I had to get a crane to lift it was I couldent get a low loader in it was at the back of a house with a curvy pebbled driveway in and the crane just about got in the allis was parked tight up against a ditch/hedgerow for over 25 /30 years and for some reason or other an elder tree decided to grow up between the engine and the track on the right hand side shooting a bow towards the turbo and causing some damage to the exhaust side of the turbo  mountings. the owner told me the reason why he parked it up was the chains were worn and he was coming towards retirement the machine worked perfect mechanically before hand he also gave me a new set of berco sprockets with it but had no chains for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote david weldon Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2018 at 3:16pm
cheers thank you I will post some more photos at a later stage when I get it up and running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote david weldon Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2018 at 3:17pm
thanks very much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote david weldon Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2018 at 3:39pm
thanks I will as I go along.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2018 at 4:58pm
The seals on the shift collector heads at the ends of the clutch shafts in the transmission are known as their weak link. They dry or rot and adhere to the shaft where they tear up under use. The upper is most likely to suffer as they stay above fluid level.
