My rant for the week
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: My rant for the week
    Posted: 16 Jun 2018 at 12:32pm
Im not a huge fan of foreign cars, however, 2008 I bought a Kia Spectra, after my son bought one and had great service with it. 130k, brakes tires and oil. there may be a sensor or something I have forgotten about, but basically it cost me very little in maintenance. It lives outside, sees a car wash maybe six times a year. rust free.
at 130k I decided to do preventative maintenance, since it is my wife's primary transport. new timing belt, water pump, hoses, belts, plugs, wires, thermostat. all were working when I replaced them and frankly, after removing them, they didn't look like they really needed replaced.
after 10 years and 130k miles, not one frozen fastener, it was like working on a new vehicle!
Today I had to replace a starter motor on my '99 F250.....freaking nightmare! everything is rusty. and the three bolts that mount the starter were all frozen solid! steel bolts through aluminum alloy starter housing and bell housing. I assume that Ford treats those bolts somehow to avoid corrosion, but if so they failed miserably. Two came out with extreme resistance, and a cheater. Some corrosion evident, but not as bad as the third because they were in blind holes in the bell housing (OK, OK I know they don't call it that anymore, but I am old school). Third, the bottom, bolt was in an open ended hole in bell housing and it would not budge, even with cheater. snake oil (I've never had that stuff work, no matter what brand or flavor), beating on the end of the bolt with air chisel, etc to no avail. finally head snapped off. OK but at least starter should come off now. NOPE! the thru hole in starter casing is still corroded to the remainder of bolt, now just a stud, as well as a boss on the mounting face of the starter that fits into bell housing spacer plate is corroded and stuck to spacer plate (plate is steel, starter casing Al alloy. Starting gently, but eventually becoming more and more violent, tapping starter, prying with prybars, etc, and, finally using air chisel to try to vibrate the corrosion loose, I got too aggressive and broke starter mounting ear, but at least starter should come off now, right? NOPE more tapping, prying......beating and prying, I finally broke the starter case even further and the starter finally DID come off. What should have been a half hour to 45 min job has taken me all morning!
After trying to remove remainder of broken bolt to no avail, I decided it only needed to bolts to hold it on and the remainder of the broken bolt will still act as an inti torque stud.
I think American manufacturers should take a closer look at their competition, Ill stick with Kia until they do.
My buddy has a Tundra, couple years now, he loves it, trouble free. If I were to buy a new truck, I think I would look real hard at the Tundra. Not likely I will be buying a new truck any time soon thought
I am still confident of this;
Wait for the Lord;
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2018 at 1:21pm
I got a 2000 Tundra, first year made.  I've done the usual maintenance like you mentioned and the timeimg belt.  Never a problem getting anything done except for pads.  To change them there are a couple pins to remove and then pull the old ones and slide in the new.  Not usually working that way.  I live on a dirt road and those pins are where they get hit the hardest with salt etc.  But other than that it's been like your Kia.  Easy as pie.
The Tundra is now made and manufactured almost entirely in the US.  The engine and trans somewhere on the east side,  The interior is made up in the NW, and the body and final assembly is in TX.  Now saying that, the new Tundras might have similar problems to your truck seeing how it's built here to, but I kinda doubt it.
BTW, look on the car door.  There should be a sticker identifying how much was made where.  Most all imports are made here now, and yours shouldn't bother you anyways, it's made by a Korean company!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2018 at 6:06pm
Lou, you needs one of these:
[TUBE]f2A8no15Ep0[/TUBE]
If you don't have the $400, then try heating the bolt with a propane torch, get it to about 400 ºF, then take a bees wax candle, and melt it against the bolt, like you were tryin to solder copper pipe.  May take a coupla tries, but usually works well!Thumbs Up
I bought the bolt buster, this winter, tried it out a lot, works better with the wax trick.  If the bolt in question is bigger than an inch and an eighth, acetylene torch is the go-to-tool...
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2018 at 7:43pm
Kia used to be considered a throw away car. Newer ones are better as long as you keep the maintenance up. Some are really nice to drive.
A Ford is still a Ford. If they can make it difficult they will. I guess to keep the techs busy because of the engineering genius behind it. Nissan is a Jap Ford in my opinion. They do things the same way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2018 at 10:35pm
Steve, $400 would be a little hard for me to justify, but it sure would be helpful at times. I was to far from the fireax to be practical, but I did seriously consider using the MAP gas torch. However, being a Ford, this truck likes to slobber oil and grease, I did not have a second person for fire watch, so I nixed that idea. (there was a day when I wouldn't even have thought about a 'fire watch', but then, there was a day when I worked on vehicles supported only by a floor jack, too). I'm getting older and more cautious with my age
One thing that I have always pondered using heat. Wouldn't heating a bolt/stud stuck in a block/bell housing, whatever only cause the bolt to expand and become even tighter? I would think heating the material around the bolt would be more productive
Wait for the Lord;
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2018 at 10:37pm
Lou, we replaced the front brakes on my grandsons Camry. Removed the front wheels, removed 1 bolt and turned the caleper 90%. Pulled the rotors replaced them, replaced the pads, returned the calaper to the original position, put the bolt back in and replaced the wheel. 15 minutes per side. Then we try'd to replace the front pads and rotors on the 07 Dodge mini van. 2.5 hours later we are still trying to get the right front calaper off. We gave up and left the old one on the van. That was the only thing easy to do on the Camry, replaced the steering rack, the timing belt and everything under the cover, you gotta pull off the intake manifold to replace the back plugs, replaced the rear subframe due to rust, and then pulled the motor apart to reseal everything, 160000 miles. Believe I'll keep the Chevy's, I get 300000+ thousand miles out of them before anything major.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2018 at 10:39pm
fixer, you are absolutely right, Kia was considered a throwaway car.....and priced accordingly. funny thing is, they preformed well beyond expectations, to the shock of many in the car world
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2018 at 10:52pm
John,
quality has become less and less about where a car is made, as humans have less and less to do with the actual production. The quality is now more to do with engineering, and, of course the eternal three way battle between marketing/engineering/accounting. It matters not who put those bolts in the starter/bell housing assembly, quality wise. What does matter is the material and processes specified by the engineers, or by the corners cut required by accounting (marketing was probably not involved in this one). We can match the quality of many of the foreign vehicles if we want, but, for some reason we often do not.
However, to be fair, I am making a case on antidotal evidence based on a very limited number of product samples. others results may vary
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2018 at 11:54pm
Lou,if you can get some heat on AL housing it will grow faster than steel bolt and help release grip....sometimes even the corroded ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2018 at 7:18am
Ya, that's what I was thinking, heat the Al casting, not the bolt,
Thanks
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2018 at 8:10am
I used some stuff a while back on a stuck bolt. I believe it was called 'freeze off'. I didn't think it would work and was about out of options, but it did. It is a Freon/penetrating oil mix. Freezes it and lubes it up at the same time.
Back when R12 was common I used it several times to free up what ever was stuck. I just put the tap on the can and let it rip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2018 at 9:41am
Had the starter replaced on my 97 F150 last year, mechanic said 'wow...original starter' I asked, how do you know ? Well it has 3 bolts in it ! Seems the 'engineers' made it a real PITA to get #3 out and in again, so most mechanics leave it out !
The pic of the bolt buster got me thinking I should make one of them.May not be as pretty as the store bought unit but only 10% of the price ! great nuther project.
Jay
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2018 at 11:21pm
Back in the day one of the things I did was alignment of big trucks. The Pete.s had a cinch bolt on the air spring that could really give you a fit. Answer: heat the head of the bolt until red hot, let it cool until red is barely gone and then smack it hard with a single jack about 3-4 times. Next a good impact would bring then out. Don't worry about spreading the head of the bolt, you can always drive a socket on.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2018 at 7:12am
Heating the bolt, and/or the housing, no matter if the housing is aluminum or not, yes you have a point, the expansion makes it tighter. But the dominating factor is that the expansion caused by the heating causes relative motion between the bolt and the hole, breaking the hold of the corrosion.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2018 at 9:26am
Worked on SIL's 2000 Tundra a time or two for bad coil packs and he did have a new starter installed after 250K miles but little else.  Wife is on her second Camry and the first was gifted to daughter and it is right @ 200K miles now.
I did put a new starter in my 94 Chevy truck last year.  Two bolts and it falls out in your hand so it took me less than a hour but I will have to consider the Tundra if and when the time comes for a replacement.  I just think the Tundra's are darn ugly.Thumbs Down
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
GaryL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GaryL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2018 at 6:42pm
Neither Kia nor Hyundai have been considered "throw away" for over 15 years.  Unlike US manufacturers, Asians tend to focus on quality and will not give up.  That's why the Japanese succeeded so well in the 70s.
Edited by GaryL - 22 Jun 2018 at 6:43pm
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2018 at 7:53am
That graph has a lot of variables in it...
 What were the problems, were they mechanical or electrical or material?
  Was the problem an easy fix?
   were the problems expensive or cheap?
    were the problems under warranty?
     were the statics for just 2018 new cars or over all the cars for 2018?
      Was it manufacturers fault or owners fault for the problem?
       My biggest thought is, Were the problems preventable while it was designed and manufactured?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2018 at 8:20am
Yea, I have ZERO LOVE for any jap unit.......... but you cant convince me that Honda is 20% worse than a Chevy !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2018 at 9:04am
Originally posted by GaryL GaryL wrote:
[QUOTE=fixer1958]
Kia/Hyundai are up to there short hairs in engine recalls for 2.0 GDI engines.
Something about the rods coming loose and locking up the engine. Free replacement up to 150K. Last one that came the guy complained of smoke under the hood and smelled electrical. Turns out he smoked the starter after it died on the highway.
There aren't very many newer ones I would trust anymore starting about 2013/14.
Things started to turn to chit about then. Mostly engineering issues from what I have seen. Gravy for the techs and major pain in the pocket for the customer.
Had another one this week, pretty new Grand Cherokee running like chit, checked the codes and and cross referenced them for TSB's and Recalls. Sure as chit there was a recall for cylinder head replacements. Verified that was the problem and sent it on it's
way back to home base to let poor souls fix it for warranty labor time. Usually about half book time or less.
Just saying one brand may not be any better than the other. Just get your favorite coin and flip it. The odds are about like that.
Edited by fixer1958 - 23 Jun 2018 at 9:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2018 at 7:17pm
After 11 years working at a car dealership I would say that graph is right on for cars. After all the problems I have had with Honda Toyota and ford pickups I will never even look at another one.
