Parts needed
Leonard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonard Quote  Post ReplyReply Direct Link To This Post Topic: Parts needed
    Posted: 13 Jul 2010 at 10:19am
Hi all, I am in need of some parts for a #7 mower.  First off I broke a knife head at the first rivet whole so no fixing it, this is the first part I need. If I can get a couple of these I'd really appreciate it.   Also am in need of the front and rear balance supports that bolt onto the right rear axle inside the fender.
Thanks
Leonard
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2010 at 1:54pm
The mounting bracket on the right side is a little different for different tractors. I have the unit for CA. I have extra cycle heads along with other mower parts. 785-353-2392
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonard Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2010 at 3:38pm
Thanks Ray.  Yeah, I forgot to mention that this set up is for a WD-45.
Will give you a call before I go to work tonight.
Leonard
Edited by Leonard - 13 Jul 2010 at 3:40pm
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2010 at 5:27pm
I have some heads and is this the bracket you need it's off a WD45.
Don
