trailer ramp springs |
mdm1
Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2720 |
Topic: trailer ramp springsPosted: 14 Jun 2018 at 6:32am |
I am thinking about putting ramp assist springs on my trailer. I have bobcat ramps and need a gorilla to lift them up. I have found some but they install on the rail which I don't have. Looking for suggestions. I should have had them put on when they built the trailer as my wife reminds me.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 14 Jun 2018 at 9:39am |
Some use a coil spring that counterbalance ramps - shaft or pin that ramps hinge on go through the center of coil spring with spring tension counterbalanceing the ramp .
CaseyCreek
Posted: 14 Jun 2018 at 10:29am |
Is this what you mean? (Gorilla-lift assisted trailer lift)
D17 Series III,D17 Series IV, 185
mdm1
Posted: 14 Jun 2018 at 11:51am |
I guess I did not know there was one by that brand name. But I don't have rails. Coke I have seen the coil spring type and was wondering if they work?
JW in MO
Joined: 16 Feb 2010 Location: South KC Area Points: 2696 |
Posted: 14 Jun 2018 at 12:02pm |
My dad had the same problem with the ramps on his lowboy when he loaded his dozer, he had a chain fashoned to the ramps and at first he would load the dozer on the lowboy just past the ramps, get off, hook the chain to the back of the dozer, pull the dozer forward and let it pull the ramps up. Later on he made a hook that he could drop as he was loading that would catch the chain and he didn't have to get off until it was loaded and the ramps were up.
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 14 Jun 2018 at 2:52pm |
mdm1, here's a couple utube video's i'm looking at for what you seek.
Hope this helps
mdm1
Posted: 14 Jun 2018 at 4:40pm |
The second one could maybe work. Thanks!
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55276 |
Posted: 14 Jun 2018 at 5:01pm |
Google trailer ramp torsion springs, about $20, IIRR
mdm1
Posted: 14 Jun 2018 at 6:58pm |
The torsion springs are what I have considered and would be by far the easiest to install.
mdm1
Posted: 15 Jun 2018 at 8:20am |
I ordered the springs. Thanks for the suggestions.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25247 |
Posted: 15 Jun 2018 at 10:11am |
please be sure to OIL the torsion springs with a 'thick' oil or rust check OFTEN, both when 'open' and when 'closed'. it ain't fun when one of them breaks..
