bushing stock - where to buy?
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Topic: bushing stock - where to buy?
    Posted: 11 Jun 2018 at 2:34pm
Who would carry steel bushing stock that is 5/8" (.625") ID and has 3/4" (or closer .747") OD  and a length of 3/4" - 13/16" (or .750" - .8125") or a tube 4 inches long and I can cut to fit.
 and 5/8" pins app. 2 " long... 1 1/2" from shoulder to cotter pin hole.
 Working on an old NH wagon steering assembly and the bushings didn't seem to have rusted, nor had the pins, considering they had no grease fittings on them.  Probably will weld the wear area on the pins and then turn them down to fit new bushings. Tia, JC
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2018 at 2:38pm
Jerry didja check McMaster Carr?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2018 at 6:04pm
My first choice would be McMaster-Carr.  If they don't have it, you might find it at MSC, Enco, or even grainger...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2018 at 7:05pm
McMaster should have the steel... but also brass and oil impregnated bronze... Might consider that for extra lube if it will handle the LOAD ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2018 at 7:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2018 at 7:13pm
oil impregnated
5/8 pin
Edited by steve(ill) - 11 Jun 2018 at 7:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2018 at 9:21pm
Thanks T-bone, DD and Steve, I had looked on the web for steel bushings and all I seem to get was high priced specialty's...
Looked at NH parts on line through Messicks... http://www.messicks.com/nh/67117
Item number 6 BUSHING
72020 $38.30 3-7 business days requires 4
 Looked for my grainger book and couldn't find it... looked at grainger on line and didn't find what I was looking for, Then called various dealers... and none had what I wanted, called Fastenal and found they have changed their sales back in March and need accounts now through them to buy. Finally called this place, they have had stuff that got me going before. http://www.ardenspecialty.com and he has some pins and bushings for me to look at tomorrow.
 Steve, Your links are almost exactly what I have been looking for. If Arden doesn't have what I need, I will be going to McMasters. Thanks much fellas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2018 at 9:42pm
Yea, local can be good... when I was running a maintenance shop I bought a lot of stuff here....
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2018 at 10:10pm
Hmmmmmm I wonder if any of these guys thought of McMaster-Carr?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2018 at 10:21pm
baum iron?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2018 at 5:42am
??  You mean I can't just go in there and buy something anymore??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2018 at 7:24am
McMaster Carr sells speed bumps for crying out loud, they gotta have everything!LOL
They sell rail car wheels.Shocked
One time at my old job, we were looking at the white board where someone had written on it with permanent marker.  Someone joked that McMaster Carr probably sold "Permanent Marker Remover for Whiteboards".  We looked it up, THEY DO!!!LOLLOLLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2018 at 6:24pm
I use to order parts from them... call by 2 PM and you had them delivered UPS by noon the next day !! ........ and YES, they sell EVERYTHING... WE use to say " If they don't have it, you didn't need it "!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2018 at 11:41pm
Ted, you can go in and set up an account, but now you have to buy a bag of bolts, nuts or what ever, no longer 5 of these three of that or whatever... suppose to stop the time wasted by the sales people dealing with us small fries, they want big business to shop from them.
  Well, today I picked up the sleeves and pins. sleeves were split, which was alright with me, had to cut a little more out of the split to press into the hole, then ran a reamer through them to fit the pins and good to go now. Took the slop out of the steering linkage and pole attachment, now to set the toe in on the wagon so it will be good to go 60 down the road. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2018 at 12:36pm
60 !!! Pinch
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2018 at 5:14pm
Fastenal has been that way for a long time here, it's been a couple of years since the one in Pittsburgh told me I had to buy in lots of 100
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 12:04am
Originally posted by STEVE STEVE wrote:
60 !!! Pinch
LOL LOL
  Remember the old folks use to say "going to beat sixty", as in working fast, or 'He was sweating to beat sixty'... or "You'll have to go like 60 to get it done"... or  "he will have to run like 60 if he is going to finish before supper time/ get the field all cut down ... etc."
  Well Steve, I sure hope for all the work of tightening up all the wear in that wagon that it will trail at any speed you want without seeing it fish tailing and swerving taking place in the rear view mirrors. Approve Yup, hopefully see it trailing straight as an arrow while yur buzzin along...   on all 8 cylinders. LOL
This page was generated in 0.891 seconds.
