How do I mount an umbrella on a WD? |
Post Reply |
allispicker
Silver Level Joined: 29 Sep 2011 Location: Iowa Points: 160 |
Posted: 10 Jun 2018 at 9:03pm |
I received a new canopy/umbrella ad a gift and itndidmt come with directions in how to mount it. Does anyone have any close up pictures with one installed?
Thanks |
Jim Hancock
Orange Level Joined: 11 Sep 2009 Location: EL Reno, Ok. Points: 1112 |
Hi.
Weld a 2' pipe(or longer) with the diameter just larger than the diameter of the umbrella pipe to a flat plate. Cut a hole in it for a 5/16" or 3/8" bolt to fit through about 2 inches from the top. Weld the matching nut over the hole to make a set screw style clamp/holder. Match drill/cut holes in the flat plate to the left tractor frame between the clutch pedal and tool box. Mount the plate, the umbrella, and tighten down the set "bolt".
Edited by Jim Hancock - 11 Jun 2018 at 12:40am |
How blessed we are by HIS GRACE!
Don(MO)
Orange Level Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Edited by Don(MO) - 11 Jun 2018 at 6:22am |
JC-WI
Orange Level Access Joined: 11 Sep 2009 Location: wisconsin Points: 33824 |
Don shows his attached to the fender, Ours were a pipe clamped to the steering post upright. Since our umbrella did not have bent pole but rather just a straight pole, it didn't need the set screw... an am sure it would work for the bent ones too. The pipe mount also doubled as a stick holder for using around the old 33 corn picker to help the occasional plugs to go through, be it was in the troufs with a stalk stuck retarding the corn going through or up in the rolls.
The truth is the truth, sugar coated or not. Trawler II says, "Remember that." |
allispicker
Thanks for the pictures and information.
garden_guy
Orange Level Joined: 05 Jul 2013 Location: Illinois Points: 1136 |
Nice pics Don. What stands out to me is that your various rear tires have different angles of the ag chevrons. Get any sort of fun traction oddities with that across your fleet?
Ted J
Orange Level Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18821 |
HOLY COW Don, what are the dimensions of your shed?
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 22459 |
Well, it's big enough he's got a road grader IN it !!!
Don(MO)
I have the mismatch tires on the wd45 with corn planter after the left side gave-up and that long bar/short bar got the call to duty, but it will get changed this fall.
the barn is 16' high and 60' wide x 80' long and it's full now.
CrestonM
Orange Level Joined: 08 Sep 2014 Location: Oklahoma Points: 8391 |
Don, where did you get those umbrella coverings?
Don(MO)
I got the one on the right from Rick and the left one wife to be painted a new John Deere knock-off umbrella from the local farm store, she has repainted a lot of them.
CrestonM
That's interesting. Looks like she did a good job!
DanC911
Orange Level Joined: 22 Jul 2014 Location: CT, USA Points: 598 |
I bought this off Ebay for $15. It was described as a WD Umbrella mount. It cleaned up nicely but I cannot figure out how/where it mounts. Any ideas? |
truckerfarmer
Orange Level Access Joined: 26 Jan 2013 Location: Watertown, SD Points: 3217 |
Thanks(1)
Without going out and measuring the bolt spacing, I'm gonna take a stab in the dark and say maybe on the fender mounting bolts. Just guessing by looking at the angle of the mounting bracket.
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
grinder220
Orange Level Joined: 11 Jan 2012 Location: Clinton Iowa Points: 2342 |
Thanks(1)
I think I've seen those brackets mounted down by the left toe plate,don't hold me to that.
Dennis J OPKs
Silver Level Joined: 12 Sep 2009 Location: Overland Park, Points: 433 |
Thanks(1)
2nd on the left side toe plate. It's not the stiffest bracket out there.
randy
Orange Level Joined: 12 Sep 2009 Location: Illinois Points: 1184 |
I mounted this canopy on my WD yeaterday. Wish i had one more. This one is about 45 years old.
Post Reply | |
