Lining a D-17 tank?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Topic: Lining a D-17 tank?
    Posted: 12 Jul 2010 at 9:58pm
I've been talked into lining my bosses D17 gas tank.  I did my WD and it came out ok.  Question is...I'm going to have to remove the fuel gauge correct?  Trying to figure out a cost for him and if I need to remove that I want to figure a new gasket.  Anyone know what that gasket costs (if there is one)?  I'm thinking a gallon of muratic acid and a quart of Red-Kote.  After that, anything I'm overlooking?
AaronSEIA
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 10:02pm
Your time?
WC, CA, D14, WD45
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 10:50pm
after you use the muriatic acid, and you flush it with water to neutraulize the acid, you need to use MEK solvent to absorb the water as per directions. I think the directions also says you can use another solvent. It is a good measure to go to their website and read directions. Just google redcote.  Dave.
