170 Questions
Smitchell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smitchell Quote  Post ReplyReply Direct Link To This Post Topic: 170 Questions
    Posted: 08 Jun 2018 at 1:17pm
I recently purchased two Allis Chalmers 170 diesels and have a few questions.  First off, what oil do I use to service?  The manual just says SAE-10W, but haven't had any luck finding just 10w without a 30 or 40 after it.  Also what hydraulic oil should I Use?  The manual says Allis 322 with an A for ATF, but is that just Automatic Transmission Fluid?  Same question about Trans Fluid in tractor, what type?  I have a couple of the cylinders that need repacking as well, but thought about just replacing the whole thing. What cylinder measurements will work for exact replacement?  Thanks in advance.
soggybottomboy View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote soggybottomboy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 2:14pm
A 15w40 diesel engine oil should be used in these tractors,or if it doesn't get below 20 degrees,30 weight diesel engine oil is ok. Transmission and hydraulic needs allis chalmers #821 transmission oil,or any equivalent power fluid.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2018 at 8:12am
yes, use 15w-40 in the engines. For the transmission and rear end use the Allis hydraulic fluid. You can use another brand if you drain and refill. I have John Deere Hy-Guard in my 185. You can use other generic fluid as well as long as you lookup he specs and it mathces the Allis #821 specs.
Don't forget to change the final drive oil too. It's usually forgotten. Refill with either 80-90 gear oil or hyd fluid.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2018 at 8:21am
There is no off the shelf cylinder that will fit.  Just get your existing cylinders repacked.  It's cheaper anyway.  A local hydraulic shop can do it if you can't.
