|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| New to me 5040 |
| Post Reply   |
| Afmedic   Bronze Level   Joined: 07 Jun 2018 Location: Kentucky Points: 6 |  Post Options  Thanks(0)  Quote  Reply  Topic: New to me 5040 Posted: 07 Jun 2018 at 11:07pm |
   I got a 5040 the other day and I'm trying to figure out how to use it  I ordered the operators manual but it isnt here yet. I've been searching for days and cant find any info info on how to shift this thing! Any insight out there? | |
| Gary Burnett   Orange Level Access   Joined: 11 Sep 2009 Location: Virginia Points: 3099 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Jun 2018 at 2:53am |
| Push the clutch down and select the gear if its the 6 speed you have two sets of gear patterns,you need to center the shifter in neutral to go from one range to the other.I'd guess you never drove an Oliver or Cockshutt tractor? | |
| Afmedic   Bronze Level   Joined: 07 Jun 2018 Location: Kentucky Points: 6 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Jun 2018 at 5:02am |
   I've never driven an Oliver or cockshutt you are correct. Do you have to push the shifter down or anything fancy or does it truly move like the pattern shows on the cover
| Gary Burnett   Orange Level Access   Joined: 11 Sep 2009 Location: Virginia Points: 3099 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Jun 2018 at 7:01am |
 It moves back and forth just like the pattern a little tricky at first but easy once you get used to it. Once bought a Case 400 from a fellow that had  owned the tractor for 10 years told me it was a great tractor but it was just geared way too high.When I went to load it I shifted it down into the low side he'd never been able to find that set of gears. | |
| Gatz in NE   Orange Level   Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1062 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Jun 2018 at 8:05am |
| Like Gary says, it can be a bit tricky to get it into gear at first......but it gets easier to do the more you use it.  No pushing down is req'd, but I found that the lever needs to be firmly held over to the left when selecting those gears (R1/1st or R2/4th IIRC) in either range. The mechanism is a bit sloppy.  Better QC or a "template" higher up on the shift lever would have helped. | |
| Afmedic   Bronze Level   Joined: 07 Jun 2018 Location: Kentucky Points: 6 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Jun 2018 at 9:11am |
   I sat on it and was able to get it in to all gears. Wow that's sloppy!no way to tighten it up any?
| Gatz in NE   Orange Level   Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1062 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Jun 2018 at 10:38am |
Ted, Nothing readily apparent for a fix. I'd thought about making that "template" mentioned above to force the shifting lever into the correct positions, but never got around to it.  (It's been sold) The PTO engage lever was also a bit sloppy; I made a stop for it. The PTO clutch (2nd stage) always seemed to drag and it was difficult to engage without some clashing of gear teeth. All in all, the 5040 was a very stout tractor and the Power Steering was excellent even with a loader. BTW, if anyone is thinking of putting a block heater in a 5040, I have the part number and source for it. | |
| Afmedic   Bronze Level   Joined: 07 Jun 2018 Location: Kentucky Points: 6 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Jun 2018 at 8:43pm |
   Is there a good source for steering parts for the 5040? I found 2 websites that sell lots of parts for it, but I cant tine the ball joint at the end of they hydraulic cylinder part on the left side of the tractor. Mine is loose as can be, and I'd like to replace it
| Gatz in NE   Orange Level   Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1062 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Jun 2018 at 11:05pm |
| have you tried Import Tractor Parts ? Is this the part you're looking for?  72091371   | |
| Gary Burnett   Orange Level Access   Joined: 11 Sep 2009 Location: Virginia Points: 3099 |  Post Options  Thanks(0)  Quote  Reply  Posted: 09 Jun 2018 at 12:24am |
   Import Tractor is a very good source for parts also ebay has lots of parts.Its about the same tractor as the Long 445 and Oliver 1265 many parts will interchange between those tractors | |
| Afmedic   Bronze Level   Joined: 07 Jun 2018 Location: Kentucky Points: 6 |  Post Options  Thanks(0)  Quote  Reply  Posted: 09 Jun 2018 at 4:42am |
   I have been looking on that site but I cant find that diagram! Number 7 is the one I need. The ball joint in mine is shot
| Gatz in NE   Orange Level   Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1062 |  Post Options  Thanks(0)  Quote  Reply  Posted: 09 Jun 2018 at 9:28am |
   the diagram I posted was from the online AGCO Parts Book Just click the box to the right of "Guest User"  Then enter 5040.   Click on the 5040 TRACTOR Scroll down to AXLES, STEERING & WHEELS, STEERING, LINKAGE (page 208) Item 7 is p/n 72090551 which is further detailed under; HYDRAULIC SYSTEM - STEERING SYSTEM, CYLINDER (page 226) This may be a hard thing to find new or if used, in good condition. The Long tractors may share this same part/assembly. I've read where Oliver 550s use the same thing. IDK Edited by Gatz in NE - 09 Jun 2018 at 9:34am | |
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
