rat ate my car
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Topic: rat ate my car
    Posted: 05 Jun 2018 at 9:02am
Car wouldn't start. Towed to dealer. They say a critter chewed
through the wires. I found some wires on ground where I parked it.
Probably a rat. $408 bill. It's always something.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 9:50am
wire insulation may be soya based.. find out, if so, sue the car maker !
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 11:42am
wire insulation is mostly peanut oil based. nuff said.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 11:50am
One of my Farmers Market neighbors has a Mitsubitshy (or however it's spelled), box truck.  Tried to start it this spring, nothing, got to looking, mouse and rat crap everywhere in the cab.  Had it hauled to the dealer, nobody would even work on it.  Ended up buying another truck.
Allis Express participant
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 3:16pm
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 3:35pm
I have seen the rats do it to a Blue tractor twice. They had several months in winter rather than overnight. The second time even ate the AC hoses. It cost a lot more than $400 to fix.
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 4:08pm
Makes buying a bag of Purina Rat Chow every once in awhile a pretty good investment. + you can use it to teach em to beg.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 4:11pm
Seems Red Squirrles are know for that also - something about the insulation is a great appitiser for vermine now
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 6:17pm
Found a rat or mouse nest, in the '94 duckoder, last week, under the air cleaner, top of right valve cover. Got it out afore it was all pissy, gonna keep my eye on it...
Saw a segment on motorweek, Pat Goss had some wire harness parts, that was treated with cayenne pepper...
[TUBE]CryrfzORyNg[/TUBE]
Edited by DiyDave - 05 Jun 2018 at 6:18pm
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 8:52pm
Lotsa deere combines were burning up back a while ago.  seems it was the insulation on the wires was soy based.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 11:37pm
Old boy called me many years ago with the left front flat on his 4400 JD combine. He wanted to combine oats. I thought I could air up the tire and then slip the jack under the frame/jack it up and fix his tire. Nope-no go. Air just shot out of the very bottom of the tire. Darn rat had chewed clear thru the bottom of the tire. Cost the old boy a new tire. His problem was easy to fix-- good luck with hour's.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2018 at 7:24am
Dirty rat.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2018 at 12:13pm
When I read the topic line, "rat ate my car" I had to see how big a rat it was to eat his car... or how small his car was.
Following isn't about rat chewing but corrosion eating that happened to me yesterday.  I had jumped in the truck, turned the key and the engine grunted over a turn and then there was no more power. Looked at the battery cable clamp and I knew it wasn't in the best of shape because part of it was broke off and had a vise grip holding it since in the winter... Well, it was still holding, Looked harder and seen the cable coming out of the clamp had corrosion on it. So since the clamp was no good, called local parts store and they had generic cables but not for the 92 ford pickup.
So I found a 2 gauge copper crimp clamp and figured the two cables would fit it. Then took a bolt cutter and cut the lead off the cables and found how bad the main starter cable really was, maybe only a quarter of it had been conducting. Cleaned up the wires and put solder compound on and shoved the cables into the clamp. Then used a little torch set  and heated  the clamp till the solder flowed in and filled the cavity and the solder past flowed out... and some solder too. Put the battery back in and tightened down the clamps and WOW!! the engine spun over faster than I ever remember. I wonder how long that cable has been a problem... Sure glad it decided to quit here at home instead of on the road someplace.   Thankful for that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2018 at 2:29pm
In my case the owner picks the poison, we keep it out year round. May be that it loses some killing power over summer. And we cannot get stuff that works to good,Snowflakes love all them fussy little critters.
This page was generated in 0.789 seconds.
