Baler pick up
Alex (wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex (wi) Quote  Post ReplyReply Direct Link To This Post Topic: Baler pick up
    Posted: 04 Jun 2018 at 11:33pm
I have an Allis Chalmers 303 and it seems to like to plug the pick up. Hay will gradually get stuffed behind the pick up teeth in front of the gathering arms. It doesn't seem to matter what ground speed. Anybody else have this problem? Remedies?
nctonyd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nctonyd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 3:19pm
yes, same thing with my 302.  Have fewer issues the drier the hay.  Also fewer issue with longer cut hay.  There is a cam adjustment you can make to alter the angle of the pickup teeth as they are pulled back threw the strippers but I have not played with that yet.
