cutting edges for dozer needed
bakwoodsfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Topic: cutting edges for dozer needed
    Posted: 03 Jun 2018 at 7:11pm
A friend of mine needs cutting edges for his dozer. Fiat-Allis 11b. Most all the places here have closed up and one place told him they were not available any longer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2018 at 8:33pm
Try Stephens equip, near Pittsburgh, PA.
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2018 at 9:01pm
You might find that it is a pretty standard cutting edge with 6 inch hole spacing.
If so any ground engaging tools place should be able to supply.
(If of European Fiat origin (which I doubt that is) check for 150 mm spacing - I was warned that it is NOT 6 inch)
Edited by Ian Beale - 03 Jun 2018 at 9:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2018 at 5:26am
Thanks
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 1:47pm
The last ones I got were through the local Case Construction dealership- they were ESCO brand, Allis part numbers for the 11S straight dozer:
70695517 blade (x3)
70606228 bit (x2)
This page was generated in 0.158 seconds.
