How many bales of hay?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Topic: How many bales of hay?
    Posted: 31 May 2018 at 12:58pm
Can you stack on your pickup bed. Seen a guy hauling a load of small squares stacked to the sky. Looked to be 6 to 7 layers. I helped my brother haul in straw bales a few years ago with an old 3/4 ton Chevy truck. Stacked 50 on the truck and 100 on the wagon it was pulling. Wish I had took a picture as the truck is long gone now.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2018 at 1:27pm
My standard load is 56.  I can do more, but 56 goes down the road nicely, I've got the tie down straps the right length to fit it, relatively stable on curves and bumps etc.
Now a 100 on your wagon?  That's pretty lame! HahahaLOLWink
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2018 at 2:54pm
I deliver 20 at a time to a neighbor and that's pretty easy to do in a standard 6ft bed
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2018 at 3:31pm
we put 50 in the bed of a 8' chevy pickup. drive around thru the pasture and put in the calving shed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2018 at 6:03pm
most I ever put on my dad's old '67 CHevy 3/4 ton pickup was 103 bales. it was also stacked real tall!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2018 at 6:57pm
I never hauled any with a truck cept to get 8 bales from the neighbor once a year.
 I know we have had 120 or more on a 14 foot hayrack many times, straw anyway. It was always lighter than good hay, so you could throw it higher.
cabinhollow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinhollow Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2018 at 8:44pm
I have a 20' trailer and a full size truck.
200 bales will stack out just right, between the two.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2018 at 10:41pm
I haul around 20 on my Toyota Tacoma.  An old neighbor used to load 90 on his 3/4 ton Ford pickup each morning to feed in a couple different pastures, trucks lasted 3 or 4 years before he wrecked them.
Allis Express participant
iowallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iowallis Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2018 at 11:28pm
Years ago had some "horsey" people come to get hay from my dad driving a Chevette. I think they could get 15 bales in one trip. Car was kind of "ass dragin'" when they left but only had to drive about 3 miles to get home.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2018 at 5:01am
the old lady....oooops….I mean the loving wife won't let me put more than 2 bales inside her burb on the carpet!
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2018 at 7:08am
You could hide a Chevette in 15 bales.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2018 at 7:56am
8 ft. box:
4 on the cut edge lengthwise to the box, gets it almost as high as the edge of the box.
Then 4 on the string side (and all the rest of the stack on the string side) across the box, overhanging the side of the box a tad.  More important to be wide enough than touch in the center.
Then 4 lengthwise stacked tight together.
Then 4 crosswise meeting snugly in the middle this time instead of worrying about width.
Then 3 lengthwise on top of that.
That's 19 per section, x 3 sections = 57, but there's only 3 between the wheel wells, so 56 total.  I'm hauling roughly 2500 pounds at that point, and a little over 2 tiers are above the cab.  1/2 of a stack thereabouts is resting on the tailgate.  It's a decent load.
I've heard of the legendary 103 bale load before, but like sasquatch, I've never seen it and have a hard time getting a visual.  Wink  I haul about 1500 bales a year to various customers, and often during the loading process I try to visualize 4 tiers taller, 6 tiers higher than the cab roof, going down the road, 2 1/2 tons of payload at least, and just can't quite visualize it!!!  I know I couldn't make it out my driveway as the trees would scrape off half the load.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2018 at 9:39pm
One of the bigger over loads on a small truck I ever saw was 25 or so 3 wire bales on a 80's Toyota. He had a system of making a v by starting 2 wide  with them up on sides of the box. Said he did every time he needed hay for his horse or 3. Never put a rope on it said they never fell off.
Back then never made a bale less than 110 pounds some pushing 140. I don't remember how those were as it was a clean the barn out sale.
Son puts as many as 15 of the 110 # on a Ford Ranger to supply a niegbhor a mile or 2 away. Turned about 350,000 miles and just put a new engine in it.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2018 at 11:29pm
50 bales with the long bed pickups
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2018 at 11:36pm
I loaded that pickup out of a large dairy barn hay mow, I would never have been able to toss them that high. I had 3 witnesses, but they is all dead now!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 1:38pm
Probably laughed themselves to death.....I'd a liked to see a picture of that too!!  I'd go out an figure it out, but I don't have any small bales around anymore....
Sherman Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sherman Farms Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 2:51pm
We can load 60 small round bales from the ground on a standard 8 foot pickup bed.
B, C, RC, 3 wc,2 wd,3 wd45, d15, d17, d19, d21, 190, 440, 7040, 918 backhoe, 12 roto balers, 7 60 combines, 40, 66,2 72,90 super, sp100, Gleaner E, F3, 3 L2, R62, and much more
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 6:44pm
A friend of mine and his brother used to load over 100 bales on an old International Pickup. There Dad always bought a lot of hay for their cows and the boys would put 2 loads on one to save a trip so they could get done early. Their Dad did not care as long as the hay got hauled! I used to haul 56 bales as I did not like to reload! Now I am all Round Bales as I have a one man operation!
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 8:44pm
UMMmmmm,,,,,UNNnnnnnn,,,,UMMmmmmm,,,,,aw chit,,never mind,,,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 11:18pm
Had a girl come and she put 5 in her Toyota corolla. Thought that was funny.
Then I used to have a cutie come get hay and would get like 40 in a dully with toolbox and box full of junk. But was stacked nice so it wouldn't fall off
Back before I was injured a friend of mine was asking what I was doing for the day hinting that he needed help. He's not a hay guy. But was going to help his mom who had horses. So I get there and the step dad says I don't know what I'm going to do the barn is full. I went up and stacked the right way and got 3 more wagon loads in there. They were amazed lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2018 at 4:43am
I had a man show up for a Round Bale with a Mini Van ! I said "You might want to think this over" ! He came back with a Snowmobile trailer !
This page was generated in 0.414 seconds.
