190 gear reduction starter
Arcs and Sparks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arcs and Sparks Quote  Post ReplyReply Direct Link To This Post Topic: 190 gear reduction starter
    Posted: 28 May 2018 at 7:07pm
I'm posting this for a person who is assembling a 190 puller out of an abandoned project tractor.  It is diesel but it has the gas engine ring gear and gas starter.  Does anyone make a gear reduction starter for a 190 that would work in that application?  The gas starter will spin the engine but just does not have the power to roll it fast enough to start it.   I restored a 190 and he just called and asked if I knew of any cure.  Its out of my league so I'll default to people with experience.   Can anyone offer any suggestions?  Any and all help is appreciated.
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2018 at 7:09am
Call Meridian Equipment in Bellingham WA. 360 398 2141. Should be able to set you up.
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2018 at 9:06am
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2018 at 5:53pm
that one will not work with the gas ring gear
