any idea what one of these is worth
marion View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marion Quote  Post ReplyReply Direct Link To This Post Topic: any idea what one of these is worth
    Posted: 28 May 2018 at 6:25am
dakotawc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dakotawc Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 6:36am
In our neck of the woods, nice WD, poor tires, 700 to 1000 dollars.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 6:53am
Maybe $1200 tops if everything is in good working condition. Depends on the market in your area and how bad someone wants it. Bad tires will bring the value down, they are $$$ to replace.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 8:53am
$800 to 1200 dollars. Nice looking WD with poor tires. Looks clean without oil spots on or under it. Drawbar is missing. Don't see any obvious farmerizations done to it. Since the three bolt front hasn't been welded up it was probably treated fairly.. Front end has probably been changed its missing two bolts in the bolster they are most likely broken off.
Edited by Dakota Dave - 28 May 2018 at 8:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 12:18pm
Estimates sound about right. It has a mag. Sheet metal looks decent. Looks to be complete. New rear tires/tubes are $1000 if you need them.
Might have been a narrow front end changed to a wide front??
Good luck.
 They will still do a bunch of work!
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 6:06pm
Yes, agree with everything said. Don't forget to subtract $50 in order to get a good "decal job" done for her...............
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 7:27pm
Pretty much agree but is a good looking wd.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2018 at 11:14pm
She's worth about 150 feet of three-bottom sixteen a minute, two hayracks up a 30% grade at 5mph...  and a 70' silage tower on a bad day.
Enough to feed a family of five AND bring plenty to market in 1954.  Today, it's worthy of subsistence at least, and pulling your truck out'a a snowdrift with a little ballast and some chains.  Wink
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2018 at 8:04am
 Driving it and hearing it run has a lot more to do with price then just being a good looking unit . How dose it run out.  I get a few customers a year  that bring me tractors and the first words out of their mouth is ,it looks so good I can not believe it has problems .
nonetheless ,still dead.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2018 at 8:48am
buying or selling? the antique tractor market has really gone down, especially with the tractors that there were several thousands made, ie WD's,WD45's, IH M and H, JD A and B, well you can get the idea now...
I f I was buying, even it is a decent looker, try to keep at $800 or less, the worn tires a big issue,  selling, I wouldn't expect to get more than $5-600, but that depends on how long ya want to wait for a buyer...
buying to flip?.. ... that sure will not work,, just something to work on to lower blood pressure,, good one to get
