B/C wiring? |
Post Reply ![]() |
MikeinLcoMo ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: west plains mo Points: 620 |
![]() ![]() ![]() ![]() ![]() Posted: 28 May 2018 at 6:22am |
Anyone have a simple wiring diagram for converting a B/C 6 volt wiring system to a voltage regulator instead of the cutout relay? Thanks, Mike.
39B 42B 48C SFW 52Cub Cub Cadet 70 S14 Speedex M14 Speedex S18 Speedex
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24696 |
someone will post, just be sure to replace 100% of the exisiting wires ! ALL of them..then she'll be good ofr the next 50 years !!
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
![]() The cut out system has the field from the generator going to a resistor on the original light switch. Low charge is through the resistor, and the resistor is bypassed straight to ground when the switch is pulled out for lights or for full charge. ![]() The regulator system has the field going to the regulator, eliminating the need for the 3 position switch.
Thank you Mr. Tucker.
Post Reply ![]() |
