for the Juice-tricians
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: for the Juice-tricians
    Posted: 25 May 2018 at 10:16am
I got a bit of a problem with the overhead fan in Dining room.some time back the dang switch on fan would only run on slow and medium so being a thrifty type person,,,,,i opened it up to see which switch to order and not finding one on web, wife wanted me to at least put together til i found switch. There were three 14 ga wires,,blue,black and white. The light used the blue and the white wires. Black wire went to fan switch,,,,SOMEWHERE,,,,!!!
There are four smaller 16 ga wires for fan. Purple, Gray, Yellow and Red. Don't really want to experiment and burn up fan motor so can the juicetricians here tell me which TWO wires to run fan on high with a regular pull switch?? Thanks for any and all help.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2018 at 11:17am
Don't suppose you could google the fan company for a wiring diagram?
Allis Express participant
Grayray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grayray Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2018 at 12:07pm
John's right.  If you know the brand and model of the fan, go to their web site, then click on support and you probably can download the manual for the fan.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2018 at 12:12pm
Yea, an electrical diagram would help a lot...
  Did you take the switch apart to see how it made contact at each 'click' of the switch?
   Many different fans out there, do like John suggested, google your fan brand...
 here is a hunter diagram...
 Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2018 at 5:23pm
Hey JC actually the dang switch fell apart when removing it!!!!
Lookin at the second dwg you posted looks to be the same as what was there before it fell apart.
What Id like to do is install a. Off/on pull switch for the High Speed Only and the heck with the medium and slow speeds.
Lookin at the dwg,,,could I install a pull switch between the big black (power) wire and the small red/yellow wires,,,??
What say ye,,,,??
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2018 at 7:26pm
Well I don't trust the btm picture... teh 'reverse switch' doesn't appear to do anything..
Normally with DPDT switches the outermost contacts 'criss cross' to revierse.
As shown the uper section.. pnk-gry-pnk, so no matter if the swicth is in the left or right spot, the gry center wire is always attached to the pnk wire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2018 at 9:11pm
if the pull switch is bad........... just hook the black and grey together to get HI.. green and brown and low and med........... black is HOT.
the capacitor is in the system to make the motor START.. better not mess with the red and yellow wires.
Edited by steve(ill) - 26 May 2018 at 9:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 9:36pm
Go on Craigslist and get a GOOD one for cheap.  There's a LOT of CRAZY people out there that just HAVE to get rid of stuff.  I could have gotten 10 of em down by my Sister for less than $10 each, like NEW....
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 5:57pm
Hey Steve and Jay,,,, guess im gonna have to fess up,,, cause like a greenhorn,, i removed the pull switch, the reverser switch and the capacitor thinkin to replace the pull switch and some of the wires to the capacitor fell off,,,,, thas, sorta why i was askin for a diagram so' s ya' ll not be thinkin too bad bout ole Joe,,,,,,, Sooooooo im dependin on you juice- tricians to bail me out
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 7:36pm
DJ, I know you are frugal (I didn't say cheap) but it might just be less expensive in the long run to buy a new fan and install it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 8:03pm
When I redid the 'back room' ( used to be the 'hot tub' room ) I bought a unit from HomeDepot that has a remote control unit. BEST cash I laid out I, the Dutchies think(er, Know ) I'm cheap ! These units control fan and light without the need to pull a 3rd (red) wire (aka 14/3). It's been 15-18 years, used a LOT and works like a charm. I'm all for recycling and such but sometimes you deserve to splurge( like the BS23s sitting here...)
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 9:14pm
yeah Joe...be safe and just go buy a new fan/light combo! i'm think'in your house and Joyce is worth more to you than what a new fan will cost! you know...there's cheap, and then there is CHEAP! DO YOU HEAR ME? CHEAP! I did the same thing on one that quit on me several years ago, when I pulled the cover off, things just didn't look good in there. tried to find another switch like it, and found nothing that would match. i'm cheap too, but not as CHEAP as you are! guess I should expect that out of a person that keeps getting ferds! (poke,poke)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2018 at 10:33pm
DJ, did you get the ceiling fan replaced yet? Saw am ad for these Big Ass fans the other day and I thought to myself "that is just what ole Joe needs."
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2018 at 11:02pm
Hubert, I was wondering that same thought the other day too.
  As for those fans in your link, are you sayin these fans might blow ol DJ out the door if they is on? LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2018 at 4:54am
Well,,,,as usual,,,,I took the advice of my friends here and took it out and put in a nice unit from Lowes as they had 3 of them on sale for a really frugal price of $39.95,,down from $117.00,,,!! They are the 52" brushed nickle with the 4 light kit and 3 speed and reversible motor. I told the salesperson I KNEW thet fellar from Nebraska that was friends with the Lowes CEO,,,,,, and,,,,and,,,she went to twitterin and stammerin and told me OK,OK,,,You can have it for ,,,,,,$39.95. Believe it or else,,,,,
I threw the old fan ona box for sale on my yard sale in the fall. Box already marked "Ran when Parked",,,
Edited by desertjoe - 13 Jun 2018 at 4:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2018 at 12:34pm
Thumbs Up   Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 12:13am
Varrooom cough cough cough Varrrooom!!! cough cough cough...
 Oh wait, Varoom, Click click click, varrooom click click click...
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 6:29am
so, DJ, did you buy ALL 3 of them ? At that price I'd have bought 2..maybe all 3 cause with gas at $5.20 USD/USG I prefer to make ONE $$ trip not several...
Also when it goes up 'someone' will say...gee 'we' could install one in this room and maybe that room.....
Jay
