Need help from fellow 653 owners
Message Reverse Sort Order
Sczarnecki90 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sczarnecki90 Quote  Post ReplyReply Direct Link To This Post Topic: Need help from fellow 653 owners
    Posted: 26 May 2018 at 9:33am
Awsome thank you very much!!!
rickv57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickv57 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2018 at 9:26am
All measurements are from bottom of cap, 20 and one quarter 2 top of range, 21 + 3/8 too low level range and also end of stick, Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sczarnecki90 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 7:15pm
Hi im new here. I just picked up a 653 crawler dozer. The previous owner who had passed away before purchase had someone weld a long piece of threaded rod to the cap for the transmission fluid(the 90w gear lube inbetween your legs). There are no indications for the fill/full zones. Wondering if i could get a fellow owner to post dip stick length in inches and then the fill/full in inches as well. Any help appreciated, thank you.
