Used antifreeze
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Topic: Used antifreeze
    Posted: 23 May 2018 at 5:37pm
I always find a proper place for my used motor oil but what do you all do to properly dispose of used antifreeze?? Ryan
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 5:55pm
When I was working we kept it in a drum and the haz mat co. picked it up.  At the time green antifreeze was not considered a haz material and could be disposed of any way you wanted to.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 6:04pm
you can take it to a oil change place' will take it or may even pay a little for it'
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 10:18pm
I've always wondered that, too. I have a 5 gallon bucket of the used green stuff, but never knew where to take it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 10:39pm
you guy's ever test that green stuff. you mite be throwing out better then what your getting ? i got 55 gallons from a auto yard a few years ago for not much cost an it tested dam;;good. an also clean.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 7:40am
The critters around my place like its taste.............that's not wrong is it?Pinch
I must admit that mine goes on the ground as I didn't know what to do with it.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 10:58am
Put it in the back tires on your Allis tractors.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 11:09am
Who ever has any around,seems to always goes away one drip at a time. Or the hose blows Cry an then got to find more.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 12:18pm
Tested how?  Freeze protection or corrosion protection?  The freeze protection doesn't go away, corrosion protection expires in time.
CaseyCreek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CaseyCreek Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 1:50pm
CTucker, you are a genius!!
I take mine to a local recycling center.  I had to call several because most places will take oil but not coolant.  I was lucky enough to find one that did.
Edited by CaseyCreek - 24 May 2018 at 1:52pm
D17 Series III,D17 Series IV, 185
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 2:45pm
I put mine in whatever plastic containers I got, mixed with oil, tranny fluid,gas,water and take to recycle center, The kid always ask was is it, I say old oil, offload then go. It ain't MY problem......they get paid big $$ for the oils and paints and such, so I don't feel bad. I do feel bad when it goes on the ground here though.
jay
VFDfireman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VFDfireman Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 7:41pm
Start with your local auto shop. Also try your local land fill...most likely they have a program for collection.
Please don’t dispose on the ground...used AF is loaded with heavy metals that can leech into the ground water and usually has fairly low pH depending on the age of it.
1954 WD45 Restored 2015
Current Project: 1953 IH R120 Pickup truck
CB
"It's better to be thought a fool than to open your mouth and remove all doubt."
Kurt WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2018 at 2:05pm
Geez you guys have that problem??? I always seem to need more new after a water pump goes ora hose blows out!
WD D17D 170 190xt 190xtIII 200 7020
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2018 at 4:28pm
I take it to work we've got an antifreeze recycler there.
Edited by Dakota Dave - 25 May 2018 at 4:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2018 at 1:37am
it will kill your pets and other animals if drank. it's a slow painful death
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2018 at 10:52am
Wish you guys were closer to me, I'd take it off your hands. We use it in the bottom of our dump trailers in the winter to keep product from freezing in.
Making a living farming with and working on Allis Equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2018 at 11:06am
ACFarmer, what "product"?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2018 at 11:21am
Scrap, coke, whatever may be wet and freeze to the bottom of the trailer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2018 at 8:43pm
guy I woked for this spring treats his dump boxes with it has a sprayer in the cab and each morning on the job spray a lite coating on box floor or onto box liner - keeps the dirt from freezing to box - as we were hauling trenching material from old sewer lines in city much of it was wet and without treating box you would have dirt frozen to metal
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2018 at 11:50pm
just don't use that recycled antifreeze. they don't put nuff of the right stuff back in it.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2018 at 6:57pm
Many car dealers will take your coolant.
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2018 at 9:45pm
This wouldn't work for 99% of you because it can't be done with a septic tank.  Here in area served by Johnson County, Ks. Wastewater it is acceptable to put anti-freeze down your drain and it causes no problem in going through the  sewage treatment plant.  Go figure.
