616/620/720 front electric clutch
Darrell, Jr. (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell, Jr. (MN) Quote  Post ReplyReply Direct Link To This Post Topic: 616/620/720 front electric clutch
    Posted: 23 May 2018 at 11:58am
The front clutch on my 620 went out last night, what's out there for new/used, and what are the going prices?
Tom IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IA Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 3:56pm
some of the parts are still available not bearing, had to go with a different bearing bushed the housing and made a couple spaces check with Sandy Lake
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell, Jr. (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2018 at 11:33pm
Thanks Tom, I was starting to think no one has ever replaced a clutch on one of these...lol...I will look into parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2018 at 5:55am
hmm.. just stopped ? Check for a broken wire. Most electric clutches draw about 3 1/2 to 4 amps of current. I've rewired a few,not hard but a long afternoon's labour. Only cost was $10 of copper wire and $5 for the 5 minute epoxy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 8:55pm
I need to learn how to rewire one. I have 2 720’s and use them on a regular bases. Sickle mower and rear tiller at the moment. Utube video?
ac720nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2018 at 5:52am
Mike Brown in Wisconsin has a line on rewiring clutches
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell, Jr. (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2018 at 9:19pm
It's not the electrical part of the clutch that's bad, it's one of the spring steel alignment fingers that broke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2018 at 10:51pm
It can probably be fixed. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell, Jr. (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2018 at 11:31am
I have already tack welded it once, I would hate to put too much on it and throw the balance off and wreck something else.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2018 at 7:47pm
Darrell, it is riveted at each end? I don't remember how that clutch looks at moment. Lots of them can be fixed with proper procedure. HTH Tracy
