99 Dodge 3500 dually rear brakes
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 99 Dodge 3500 dually rear brakes
    Posted: 22 May 2018 at 4:26pm
I replaced the brake lines on my 99 Dodge dually and twisted off a brake cylinder bleeder; gonna try an easy out but really doubtfull it will work , I did heat it some last night, hoping it just comes right out;; heres my question, if I have to get inside the drum do I have to pull the axle ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2018 at 5:15pm
are they backward threads?
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2018 at 5:38pm
No you do not have to pull the axle  The drums are outboard set up the same as a highway truck uni-mount type.  I would just replace the wheel cylinder you will likely find it is fairly cheap for the work involved in getting the bleeder out. On mine it is so tiny it would drive me nuts doing it up in behind the spring bundle
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2018 at 5:38pm
No just lever been blead in the 14 years ive owned it the other side worked good, Thanks Amos, I see this now, now trying to get the drum off, wow it seems to be stuck tight
Edited by DougG - 22 May 2018 at 5:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2018 at 6:16pm
I got it off ! went to YouTube and some dude had a video of running them without wheels on- only one nut on ,, put it in 3 gear ran it and hit the brakes a few times, IT WORKED !
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2018 at 6:18pm
Make sure the parking brake isn't on holding the drum. Been there and it was pretty embarrassing
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 11:08am
Yes you have to pull the axel. The brake drum is held to the drum buy the studs they have to be pressed out. Just pull the axle and the hub and drum come off together. I did my dually two years ago the new wheel cylinders were only around $10 each. It wasn't worth the effort to mess with them.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 6:56pm
You may be able to bleed it just by loosening the brake line.  I've seen that done before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 8:51pm
Ahhh good call John, makes sense,, I got it all together now , no pulling of the axle ,,no removing brake springs, it was a pretty easy deal actually
Edited by DougG - 24 May 2018 at 7:12pm
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 10:02pm
Dave, I think you are refering to the earlier style of rear drum
This page was generated in 0.590 seconds.
