Hydraulic Issue
Allis Wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic Issue
    Posted: 21 May 2018 at 3:35pm
My Wd45 is leaking hydraulic oil internally. I can fill the hydraulics up and not even use them and a couple days later it’s low again. I’m thinking it’s leaking into the transmission because after this happens the transmission is over full. I’m wondering if I can use it like this as long as the tranny isn’t over full since I don’t use the hydraulics. What could be the issue and how hard of a fix is it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2018 at 3:43pm
The thing is...the hyd has to run in oil or will destroy cam and followers for pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2018 at 3:44pm
I believe I'd keep filling the hydraulic compartment and the problem may eventually cure itself when the oil levels are the same. Don't think it will hurt anything. The fix is remove the torque housing from the tractor and reseal the clutch shaft.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2018 at 3:56pm
And if you use hy-tran fluid in all compartments then everyone is happy.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2018 at 4:13pm
I'm with Stan and Doc, matter of fact I have a WD that is filled to one level and it does just fine.   Useing universal tractor fluid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2018 at 5:39pm
I’ve been using tractor tranny in the hydraulics so I’ll just keep using that and keep an eye on the transmission fluid level. Thanks all
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2018 at 9:21pm
May have axel seals leaking next.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2018 at 9:39pm
Mack do you mean hydraulic fluid leaking in the axle fluid?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2018 at 10:31pm
I think he means the pinion seals leaking rear end oil out next to brake drums. You would see the oil coming out the bottom of the brake housing. Seals are probably already worn out but go unnoticed because heavy oil (80-90 weight) will leak slowly vs the lighter hydraulic oil which you would probably notice immediately.
Wink
I am a Russian Bot
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2018 at 7:49am
That's what I'm experiencing.  I'm using it as is for now.  Someday, it'll get torn down, re-do the brakes, re-do the axle seals, probably even split it to fix the seals between the hydraulics and tranny.
It's been this way for at least 10 years so I guess I'm not doing any more damage to it.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2018 at 9:39am
I replace the clutch shaft seals on my 45 a couple years ago. It not terribly difficult but is labor intensive.
