V8 |
Mikez
Topic: V8Posted: 20 May 2018 at 11:04pm |
Hey was watching tractor pulls on RFD today. There's was a newer Massey with a v8 in it, was wondering what the base engine is, did Massey have v8 in that style tractor. Just curious, thanks
dawntreader74
Posted: 20 May 2018 at 11:21pm |
that massey was a V8' there was a lot of masseys with the V8 the manifold gets red hot.was it the 10000 pro' stock?
Edited by dawntreader74 - 20 May 2018 at 11:23pm |
Mikez
Posted: 20 May 2018 at 11:29pm |
I don't remember what class, sorry. Yes it got red hot.
IV seen the older one with them. But cool |
Butch(OH)
Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3842 |
Posted: 21 May 2018 at 7:17am |
Yes Massey used a V8 made by Perkins in several models. We have a good one locally. check out Carton Cope Warpath.
DrAllis
Posted: 21 May 2018 at 8:52am |
When I grow up, I wanna be like Carlton Cope !!!!!
DanWi
Posted: 21 May 2018 at 11:25am |
Prostock class from Hillsboro Wisconsin
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5206 |
Posted: 21 May 2018 at 12:38pm |
Perkins 640 V8 in those pro-stocks! Very impressive to watch run! The 1150 came out with a 510 V8, then went to 540 for the 1155 and the 2745/2775 I think. The 640 was used in the 2800/2805 some 860 combines and the White 9200/9720 combines.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9002 |
Posted: 06 Jun 2018 at 12:02am |
Neighbors had Masseys .Last upgrade was a 2805.Was a horse when it wasn't in the shop! Engine got in their pocket one too many times.Down the road it went! Still has a couple 1100 series but everything else is Green.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42276 |
Posted: 09 Jun 2018 at 7:26pm |
Not a V engine but a story on one of the first high HP tractors using GM Diesel
https://www.hemmings.com/magazine/hmn/2008/07/Oliver-Super-99-Diesel/1659600.html |
Coke-in-MN
Posted: 09 Jun 2018 at 7:33pm |
seems another GM diesel was used also
https://www.dieselworldmag.com/features/2936-2/ |
7040
Joined: 11 Aug 2013 Location: newglarus wi Points: 418 |
Posted: 09 Jun 2018 at 9:20pm |
Mike Everson from Belleville WI.built a newer body style Massey with the 640 v8. Called sleepnir (Norwegian mythical 8 legged horse) it pulled fot the first time in 2017. He is a huge massey fan and spent 3 years building it if this is the same tractor he went through 6 header designs before he got one to hold up where the four pipes come together that piece started out as a 70 lbs chunk of stainless and he machined that himself he does own a machine shop though.
Edited by 7040 - 09 Jun 2018 at 9:22pm |
dawntreader74
Posted: 26 Jun 2018 at 12:11am |
did the 2255 oliver used the 3208' V8 CAT motor. they pull good also.
injpumpEd
Posted: 26 Jun 2018 at 7:47am |
The early 2255 used the Cat 3150 573 CID engine. Later in production, they went to the 3208 which is 636 CID. The 3208 is an update/improvement of the earlier 1150/3150, 1160/3160. the 11 being truck engines, 31 being industrial engines, the 50 being 573, 60 were 636. confused yet? lol! I would imagine Oliver/White switched to the 3208 because the 3150 was likely discontinued when the 3208 came out.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4079 |
Posted: 05 Jul 2018 at 9:12am |
i have been going to to ask who uses cat perkins or other engines be sides the red and green ones
