ya'll ever see...
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Topic: ya'll ever see...
    Posted: 17 May 2018 at 11:04pm
a window air conditioner fall out a second story window? it ain't pretty!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2018 at 2:57am
o-k...went and bought another window a/c unit and platered with stickers all over the exterior of the unit, it says: caution this unit uses flammable coolant...yada,yada,yada! what are they using for that stuff?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2018 at 6:35am
Had a small unit fall out years ago, stuck it back in the window and it worked. They are probably using butane for a refrigerant. That is one of the things that was used as a substitute for R12 in older automotive systems when the gubbmint did away with R12.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2018 at 6:41am
Hot compressed butane !?!?  Yet they want to take our guns away.
7040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2018 at 7:27am
Government /EPA logic. It's because they want no cfc refrigerant or blends by 2020. So all other current affordable options are flammable. So the 5 pounds of refrigerant that are used to cool your house won't damage the ozone layer if they leak out. But what happens when houses start burning down do to leaks. How's that for the environment and ozone layer
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2018 at 11:41am
Don't the new units have an escape pod so if it gets on fire, it blows its self away from the window, into the yard?
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2018 at 3:52pm
well if it does John, it'll hafta blow before the fire dept gits here, cuz they'll destroy it if it hasn't blown out!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2018 at 12:04pm
Shameless, Shameless, Shameless,,,,,,,,,why you pickin on the FD??  Just a bunch of hard working guys trying to save your azzzzzz.
Is this just another ploy to make our cars and trucks obsolete because of the old R34 just like the R12?  Force us to buy newer?
This page was generated in 0.371 seconds.
