24.5 x 32 Tires for 7000lb Mod Farm Class
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: 24.5 x 32 Tires for 7000lb Mod Farm Class
    Posted: 17 May 2018 at 8:27am
I am building a 190XT for a Super Light 7000lb Mod Farm Class.  Cube limit is 330 with a 2.3 charger and 3100rpms.  Max tire size is 18.4x38, but I own a set of 24.5 x 32 tires.  I always was a fan of the 38's and thought they were a better all around tire, but what are your thoughts on the 24.5's???  Thanks for the input!
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2018 at 1:00pm
Big tires take more HP to turn, in these lower hp classes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2018 at 1:08pm
That is true.  I'm not going to get rid of them, though.  I may step up to light pro stock in the future, so they would work well there.  Just wondering if the footprint is much bigger than on the 18.4x38?
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2018 at 8:21am
Foot print is closer to a 20.8x38.
Making a living farming with and working on Allis Equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2018 at 8:34am
Thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2018 at 12:24am
If your class has a limit of an 18.4X38, why are you even asking about 24.5X32s😳
Edited by PaulB - 21 May 2018 at 4:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2018 at 7:12am
As per the Firestone tire footprint chart, a 20.8 x 38 has a flat plate area of 380 square inches and a 24.5 x 32 has 430 square inches.  Looks to me like more than 10% difference between the two tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2018 at 7:45pm
They aren't exactly the same, but they are close. Any given night a tractor on 20.8 can get by a tractor on 24.5 in the hot farm class around here. Then factor in the new cast just for pulling 20.8s that are out now and they get even closer on footprint.
